hb69's ph1 Zetec S (28/8/12)Silverstone and a few other bits : Member's Gallery - Page 2 | Fiesta Forums
Re: hb69's ph1 Zetec S
Postby dontpannic on Mon Mar 26, 2012 10:15 pm
jonyb4 :not in the slightest, they go on the bottom end very commonly
most of them dont reach 100k
no they don't!
Its the same with any engine, you don't put oil in, it dies. I've seen phase one ZS engines going 200k plus! You're telling me that they don't make 100k?
Postby jonyb4 on Tue Mar 27, 2012 12:42 am
ah well im going overboard a bit, but they are weak, especially since the 1.3 hcs was also available which out lasted them by miles
nick, ive lost count how many ive seen die, rob had two 1.25's die in his mk4 alone
theyre nicknamed throw away engines for a reason
Postby trecoll on Tue Mar 27, 2012 8:48 am
jonyb4 :rob had two 1.25's die in his mk4 alone
Three things;
  • The first was dead when I got it, I nursed it for 6 months
  • The second was on 150k, I drove it for 30,000 VERY hard miles, flat out everywhere sometimes without oil
  • Why drag me into this cause of your dislike for something?
trecoll
Postby Minstral on Tue Mar 27, 2012 10:13 am
mine was the phase 2, had some service history i serviced it was around 80k aboused for 3 trackdays was fine, as long as its been looked after somewhat they will go on.
i think that the phase 1 must just suffer a bit more when pushed and not looked after when compared to the phase 2. but there are plenty that have many miles on phase 1's that is
Minstral
Your car: *
Postby Michael! on Tue Mar 27, 2012 11:16 am
Friend of mine has a cammed + carbed One and it's been around the world at least 3 times... Sure the mileage is something like 140k strongest engine I know. Services every 6 months with genuine ford parts etc...
ft-com-members-map-vt190192/
Michael!
Postby MK2 Jamie on Tue Mar 27, 2012 12:44 pm
My zs was on like 115k and still going strong. Hitting the limiter from cold was a regular occurrence too.
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby Minstral on Tue Mar 27, 2012 2:37 pm
MK2 Jamie :My zs was on like 115k and still going strong. Hitting the limiter from cold was a regular occurrence too.
hope it was only when it was cold
Minstral
Your car: *
Postby dontpannic on Tue Mar 27, 2012 2:40 pm
Minstral :
You can cause serious damage if you hit the limiter when its hot.
Postby MK2 Jamie on Tue Mar 27, 2012 4:02 pm
I hit the rev limiter once when it was hot...never again am I doing that.
MK2 Jamie
Postby hb69 on Tue Mar 27, 2012 11:03 pm
You should only rag it from cold, prefferably with no oil
Jony, i should point out here i actually dont care if other peoples engines have broken for whatever reason, mine hasnt, thats all i care about.
hb69
Your car: Fiesta 1.1 LX
Postby Michael! on Tue Mar 27, 2012 11:08 pm
i love how much love there is for jony on this forum, makes me warm inside
Michael!
Postby Tweek on Tue Mar 27, 2012 11:15 pm
Pouring Anti-Freeze in with the oil helps those engines with cold starts too.
Your car: VW Golf GTD
Postby jonyb4 on Wed Mar 28, 2012 12:22 am
Michael! :i love how much love there is for jony on this forum, makes me warm inside
people get pokey when you touch a nerve, theyre nippy and humble engines, but as a whole, very weak when compared to a zetec, hcs or cvh
ive actutally witnessed a hsc being run with next to no oil for over 3 years and it was stilling running
Postby fiend on Wed Mar 28, 2012 12:53 am
Jony is right.
Time to drop the 1.6 Zetec SE and fit a 1.1 HCS from a pop plus. Its the way forward.
fiend
Postby bakewell001 on Wed Mar 28, 2012 7:27 am
fiend :Jony is right.
:lol: beat me to it!
It's the only way really, I wouldn't risk using such a weak engine.
bakewell001
Postby trecoll on Wed Mar 28, 2012 9:24 am
trecoll :
Three things;
Oh and 4.
  • I also blew up my old 1.3 HCS in my mk3...
trecoll
hb69's ph1 Zetec S
Postby dontpannic on Wed Mar 28, 2012 3:04 pm
Wayne, antifreeze is a very good tip, another, if you want the engine to move slower for increased fuel economy you can also put self raising flour in with the oil to thicken it up.
Postby MK2 Jamie on Wed Mar 28, 2012 3:39 pm
You need to write a book and name it 'Sheriff Burmans top tips'
MK2 Jamie
Postby dontpannic on Wed Mar 28, 2012 3:54 pm
:lol: :lol: :lol: Such a good idea.
Postby Tygress on Wed Mar 28, 2012 10:56 pm
I Agree With You Henry They Are Not Crap, They Are Brilliant So Shush That Moosh Of Yours Jony B, ^_^ Just Sayin! :aviator:
Don't Be Afraid Of Fear, Let It Be Afraid Of You!
Tygress
Your car: Ford Fiesta Zetec S!
Postby jonyb4 on Wed Mar 28, 2012 11:04 pm
LOL flour!
sorry jesh :)
Postby hb69 on Wed Mar 28, 2012 11:57 pm
I got on eBay as soon as I heard my engine wasn't very good because it should have blown up at 100k because the Internet says so. found a couple of 1.1 hcs, but ideally want a 1.3 hcs for a bit more poke, might do a thread on how easy is it to turbo an hcs
Wayne, oil in the coolant is a good way of keeping it lubricated. The Mazda ran ok on it :lol:
hb69
Postby dontpannic on Thu Mar 29, 2012 7:44 am
hb69 :I got on eBay as soon as I heard my engine wasn't very good because it should have blown up at 100k because the Internet says so. found a couple of 1.1 hcs, but ideally want a 1.3 hcs for a bit more poke, might do a thread on how easy is it to turbo an hcs
:lol: :lol: :lol:
Ah but then you had the side effect of the coolant pipe slipping off the back of the engine. Which reminds me of another tip, you have to fasten your hoses with cable ties as jubilee clips just aren't strong enough with the increased pressure of oily coolant.
Postby - Danny Boy - on Thu Mar 29, 2012 10:35 am
Can you get away with doubling over an elastic band if you have run out of cable ties? Its quite a strong elastic band so it should be ok?
- Danny Boy -
Your car: Fiesta Si 2.0
Postby dontpannic on Thu Mar 29, 2012 10:46 am
- Danny Boy - :Can you get away with doubling over an elastic band if you have run out of cable ties? Its quite a strong elastic band so it should be ok?
Only if you anchor the band to the exhaust manifold. Don't worry, you'll only be ragging it from cold so you'll be fine.
Postby hb69 on Thu Mar 29, 2012 11:36 am
Thats what i was thinking, ideally running it with no coolant is best
hb69
Postby trecoll on Thu Mar 29, 2012 11:58 am
I was told it was best with these 'weak' engines to swap the coolant and oil around.
It makes it run cooler so that it cant get hot enough to break, but the coolant is just enough lubricant to keep it running ok.
trecoll
Postby - Danny Boy - on Thu Mar 29, 2012 1:05 pm
dontpannic :
Perfect!! I'll replace all my jubilie clips with exastic bands tomorrow then.
I dont know if anyone else does it, but I like to start mine with the throttle wide open and bounce it off the limiter for about 5 minutes as soon as it starts up, I heard that if you do that everyday it makes the engine produce more power because the ECU thinks its in race mode.
- Danny Boy -
Postby hb69 on Thu Mar 29, 2012 1:49 pm
- Danny Boy - :
dontpannic :
:lol: :lol:
I heard thats how Wayne does his remaps, there was a magazine article on it a few months back iirc
As my engines well overdue blowing up ive found a replacement
http://www.ebay.co.uk/itm/FORD-FIESTA-1-1-MK3-ENGINE-/160685915649?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2569a07e01
Cant wait to get it fitted and enjoy a bit of reliablilty, should be more fun on track days too, as ill have the knowledge it will keep running with no oil :aviator:
hb69
Postby dontpannic on Thu Mar 29, 2012 1:51 pm
Only 55k though, but he says its a quiet runner which is such a bad thing, it means that the metal in the engine isn't banging together properly. Shame.
Postby - Danny Boy - on Thu Mar 29, 2012 1:58 pm
I would go with this one personally:
http://www.ebay.co.uk/itm/FIESTA-MK4-13 ... 3a6ef6a01d
Its covered over 100,000 miles so you know for a fact it will never die as its gone past the 100,000 mile marker now. Doesn't overheat - he must be using coolant in the oil, what a top bloke! And also has the usual rattle so you know its all banging together nicely!
You're onto a winner with that one if you ask me!
- Danny Boy -
Postby hb69 on Thu Mar 29, 2012 2:01 pm
You reckon it will be quick Danny? or will i need a k&n for a definate 5bhp increase?
hb69
Postby - Danny Boy - on Thu Mar 29, 2012 2:11 pm
Yeah for sure! My old 1.3 HCS was on like 120k and it could keep up with a lot of cars!
I think a K&N will restict the power a bit, I would just leave the air filter off completely for the best results.
- Danny Boy -
Postby dontpannic on Thu Mar 29, 2012 2:15 pm
- Danny Boy - :Yeah for sure! My old 1.3 HCS was on like 120k and it could keep up with a lot of cars!
What are you talking about? You shouldn't be letting the engine get any air in otherwise you'll cool down the pistons and you don't want that to happen.
Henry, if you went for the 100,000 miler you won't need an exhaust either.
Postby hb69 on Sat Apr 07, 2012 3:18 pm
Dropped it off at the bodyshop this morning. Was so nervous going there after the internet said my engine is due to expire, but im pleased to report it made it there
hb69
