hb69's ph1 Zetec S (28/8/12)Silverstone and a few other bits
174 posts • Page 2 of 5 • 1, 2, 3, 4, 5
Re: hb69's ph1 Zetec S
jonyb4 :not in the slightest, they go on the bottom end very commonly
most of them dont reach 100k
no they don't!
Its the same with any engine, you don't put oil in, it dies. I've seen phase one ZS engines going 200k plus! You're telling me that they don't make 100k?
- dontpannic
ah well im going overboard a bit, but they are weak, especially since the 1.3 hcs was also available which out lasted them by miles
nick, ive lost count how many ive seen die, rob had two 1.25's die in his mk4 alone
theyre nicknamed throw away engines for a reason
jonyb4 :rob had two 1.25's die in his mk4 alone
Three things;
- The first was dead when I got it, I nursed it for 6 months
- The second was on 150k, I drove it for 30,000 VERY hard miles, flat out everywhere sometimes without oil
- Why drag me into this cause of your dislike for something?
- trecoll
mine was the phase 2, had some service history i serviced it was around 80k aboused for 3 trackdays was fine, as long as its been looked after somewhat they will go on.
i think that the phase 1 must just suffer a bit more when pushed and not looked after when compared to the phase 2. but there are plenty that have many miles on phase 1's that is
- Minstral
- Your car: *
Friend of mine has a cammed + carbed One and it's been around the world at least 3 times... Sure the mileage is something like 140k strongest engine I know. Services every 6 months with genuine ford parts etc...
- Michael!
My zs was on like 115k and still going strong. Hitting the limiter from cold was a regular occurrence too.
- MK2 Jamie
MK2 Jamie :My zs was on like 115k and still going strong. Hitting the limiter from cold was a regular occurrence too.
hope it was only when it was cold
- Minstral
- Your car: *
Minstral :MK2 Jamie :My zs was on like 115k and still going strong. Hitting the limiter from cold was a regular occurrence too.
You can cause serious damage if you hit the limiter when its hot.
- dontpannic
I hit the rev limiter once when it was hot...never again am I doing that.
- MK2 Jamie
You should only rag it from cold, prefferably with no oil
Jony, i should point out here i actually dont care if other peoples engines have broken for whatever reason, mine hasnt, thats all i care about.
- hb69
- Your car: Fiesta 1.1 LX
i love how much love there is for jony on this forum, makes me warm inside
- Michael!
Pouring Anti-Freeze in with the oil helps those engines with cold starts too.
- Tweek
- Your car: VW Golf GTD
Michael! :i love how much love there is for jony on this forum, makes me warm inside
people get pokey when you touch a nerve, theyre nippy and humble engines, but as a whole, very weak when compared to a zetec, hcs or cvh
ive actutally witnessed a hsc being run with next to no oil for over 3 years and it was stilling running
Jony is right.
Time to drop the 1.6 Zetec SE and fit a 1.1 HCS from a pop plus. Its the way forward.
- fiend
fiend :Jony is right.
beat me to it!
It's the only way really, I wouldn't risk using such a weak engine.
- bakewell001
trecoll :jonyb4 :rob had two 1.25's die in his mk4 alone
Three things;
Oh and 4.
- I also blew up my old 1.3 HCS in my mk3...
- trecoll
hb69's ph1 Zetec S
Wayne, antifreeze is a very good tip, another, if you want the engine to move slower for increased fuel economy you can also put self raising flour in with the oil to thicken it up.
- dontpannic
You need to write a book and name it 'Sheriff Burmans top tips'
- MK2 Jamie
- dontpannic
I Agree With You Henry They Are Not Crap, They Are Brilliant So Shush That Moosh Of Yours Jony B, ^_^ Just Sayin!
Don't Be Afraid Of Fear, Let It Be Afraid Of You!
- Tygress
- Your car: Ford Fiesta Zetec S!
I got on eBay as soon as I heard my engine wasn't very good because it should have blown up at 100k because the Internet says so. found a couple of 1.1 hcs, but ideally want a 1.3 hcs for a bit more poke, might do a thread on how easy is it to turbo an hcs
Wayne, oil in the coolant is a good way of keeping it lubricated. The Mazda ran ok on it
- hb69
hb69 :I got on eBay as soon as I heard my engine wasn't very good because it should have blown up at 100k because the Internet says so. found a couple of 1.1 hcs, but ideally want a 1.3 hcs for a bit more poke, might do a thread on how easy is it to turbo an hcs
Ah but then you had the side effect of the coolant pipe slipping off the back of the engine. Which reminds me of another tip, you have to fasten your hoses with cable ties as jubilee clips just aren't strong enough with the increased pressure of oily coolant.
- dontpannic
Can you get away with doubling over an elastic band if you have run out of cable ties? Its quite a strong elastic band so it should be ok?
- - Danny Boy -
- Your car: Fiesta Si 2.0
- Danny Boy - :Can you get away with doubling over an elastic band if you have run out of cable ties? Its quite a strong elastic band so it should be ok?
Only if you anchor the band to the exhaust manifold. Don't worry, you'll only be ragging it from cold so you'll be fine.
- dontpannic
Thats what i was thinking, ideally running it with no coolant is best
- hb69
I was told it was best with these 'weak' engines to swap the coolant and oil around.
It makes it run cooler so that it cant get hot enough to break, but the coolant is just enough lubricant to keep it running ok.
- trecoll
dontpannic :- Danny Boy - :Can you get away with doubling over an elastic band if you have run out of cable ties? Its quite a strong elastic band so it should be ok?
Perfect!! I'll replace all my jubilie clips with exastic bands tomorrow then.
I dont know if anyone else does it, but I like to start mine with the throttle wide open and bounce it off the limiter for about 5 minutes as soon as it starts up, I heard that if you do that everyday it makes the engine produce more power because the ECU thinks its in race mode.
- - Danny Boy -
- Danny Boy - :dontpannic :- Danny Boy - :Can you get away with doubling over an elastic band if you have run out of cable ties? Its quite a strong elastic band so it should be ok?
I heard thats how Wayne does his remaps, there was a magazine article on it a few months back iirc
As my engines well overdue blowing up ive found a replacement
http://www.ebay.co.uk/itm/FORD-FIESTA-1-1-MK3-ENGINE-/160685915649?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2569a07e01
Cant wait to get it fitted and enjoy a bit of reliablilty, should be more fun on track days too, as ill have the knowledge it will keep running with no oil
- hb69
Only 55k though, but he says its a quiet runner which is such a bad thing, it means that the metal in the engine isn't banging together properly. Shame.
- dontpannic
I would go with this one personally:
http://www.ebay.co.uk/itm/FIESTA-MK4-13 ... 3a6ef6a01d
Its covered over 100,000 miles so you know for a fact it will never die as its gone past the 100,000 mile marker now. Doesn't overheat - he must be using coolant in the oil, what a top bloke! And also has the usual rattle so you know its all banging together nicely!
You're onto a winner with that one if you ask me!
- - Danny Boy -
You reckon it will be quick Danny? or will i need a k&n for a definate 5bhp increase?
- hb69
Yeah for sure! My old 1.3 HCS was on like 120k and it could keep up with a lot of cars!
I think a K&N will restict the power a bit, I would just leave the air filter off completely for the best results.
- - Danny Boy -
- Danny Boy - :Yeah for sure! My old 1.3 HCS was on like 120k and it could keep up with a lot of cars!
What are you talking about? You shouldn't be letting the engine get any air in otherwise you'll cool down the pistons and you don't want that to happen.
Henry, if you went for the 100,000 miler you won't need an exhaust either.
- dontpannic
Dropped it off at the bodyshop this morning. Was so nervous going there after the internet said my engine is due to expire, but im pleased to report it made it there
- hb69
