[boring lecture] headlights
Postby Project on Sun May 23, 2004 4:40 am
Project
fiftyoneCL
fiftyoneCL
Postby Tom SX on Sun May 23, 2004 10:10 am
Mr Sterns Website is indeed very informative! I've just spent 2hrs reading that and How Stuff Works learning about lights for no apparent reason :)
Does anyone have any good links about the design of H4 bulbs and headlamps, as I've yet to look into this? :-?
Tom SX
Your car: A big German gaymobile
Postby FezzR on Sun May 23, 2004 11:02 am
very wise investment if u drive on unlit roads regularly
FezzR
God Damn Lazy
God Damn Lazy
Postby Excursion on Sun May 23, 2004 11:39 am
Higher colour temperature bulbs give out less lumens :) A 4200/4300K is the best bulb to get for illumination, it is the closet to daylight.
My Fiesta will be back next year with Bi-Xenons's :)
Postby Project on Sun May 23, 2004 3:27 pm
Bi-Xenons?!
Oooh, you cheeky scamp :D
Project
fiftyoneCL
fiftyoneCL
Postby Excursion on Sun May 23, 2004 4:30 pm
Alan Fibblesnork :Oooh, you cheeky scamp :D
Postby Project on Tue May 25, 2004 11:36 pm
Also found this Auto Express test:
http://www.zx-12r.org/Motorcycle_info/I ... 20Test.htm
Very interesting! (Yes, I'm bored... :D).
Project
fiftyoneCL
fiftyoneCL
Postby Project on Wed May 26, 2004 3:26 am
Right, this is now going in the guides section 'cos I've just spent a very boring hour writing up a new article.
If you don't like it, you can always kiss my ass :P
Project
fiftyoneCL
fiftyoneCL
Postby Badgerboy on Wed May 26, 2004 1:18 pm
In the non-legal area, Ring produce the Sportz Blue 100/80W bulb, which is a halogen (not Xenon-enhanced), heavily blue tinted bulb. These give off a pleasant white light around the 5,000K mark, but don't give the best or most even light on the road at night, as the blue coating cuts out a huge amount of visible light. Similar bulbs are available which are only rated at 55/60W, especially those imported from Japan and Korea, and which commonly have extremely poor build quality and light output.
Ah, these would be the bulbs I've been driving around with for a year! After reading this I went and got the packaging to have look. Seems my local spares place accidently put the price sticker over the 'For Show Use Only' part. baxtered
Still, never had problems with them, and the police have never done me for them. MOT is up 1st of July, would it be a good idea to swap the bulbs out?
Badgerboy
Postby Project on Wed May 26, 2004 2:23 pm
Yeah - a sharp-eyed MOT inspector will fail it for the headlights looking "blue" or being too intense (but they can't take the bulbs out to check them though).
Project
fiftyoneCL
fiftyoneCL
Postby Badgerboy on Wed May 26, 2004 5:00 pm
Swapped.
I'll keep the blue ones for special days.
Badgerboy
Postby wywywywy on Thu May 27, 2004 12:40 pm
(simply increasing output by 50% would not be legal) - again this is all down to the placement and size of the filament. At the peak points, a 50% increase in light output would mean a 55W bulb producing 88W.
Interesting.
I thought they were using better technologies to higher the efficiency of normal bulbs.
You know, a 55w bulb produce only around 25w of light, all other energy is wasted to heat - so I thought they were doing something like "energy saving bulbs", i.e. same amount of electricity but more to light, less to heat.
By the way, how do you know where a bulb has got Xenon in it or not? Because now every manufacturer calls their product "Super Hyper Uprate Ultra High-density Xenon Performance HID".
Fiesta Mk3 The Complete FAQ
Have a look, and do a search, before you ask anything :)
Project Log
wywywywy
Postby Project on Thu May 27, 2004 3:00 pm
wywywy - a small amount of Xenon gas in a filament lamp helps the bulb to burn hotter and whiter, which increases light output a small amount.
In my humble experience, any bulb that uses the letters "HID" anywhere on the packaging is a marketing scam aimed at people too vain to buy bulbs for their practicality and too tight to pay for a proper HID system ;)
Al
Project
fiftyoneCL
fiftyoneCL
Postby Gaz7 on Thu May 27, 2004 8:51 pm
Just a quick point to add about HID xenon systems - it's UK and USA law that all vehicles fitted with xenons must have self levelling systems, and rather bizarrely, electric headlight washers fitted also. The car will not pass an MOT without these two things.
Gareth :)
Gaz7
Authorised Trader
Authorised Trader
Postby Mikee_RS on Thu May 27, 2004 10:46 pm
mmm im bored but not THAT bored
Image Image Image
Mikee_RS
Car: 1995 Ford Fiesta
Postby Project on Mon May 31, 2004 3:27 am
Mikee - :P, but you're right :D
Updated with pics and something new from Osram ;)
Al
Project
fiftyoneCL
fiftyoneCL
Postby ~Tony~ on Tue Jun 01, 2004 9:28 am
interesting al
i use the ring ultra xenon bulbs in my car.
you can notice a brighter light output when driving on unlit roads. other than that you can't notice any difference when driving in street lit areas :D
still need to update this sig
~Tony~
Postby mikester on Thu Jun 17, 2004 11:30 am
are blue sifdelights actually legal??
RW801
Performance Halogen Bulbs
Upgrade From R501
Voltage 12v
Wattage 5w
Cap W5W
just replace your normal sidelights with these ones for £3 and you have blue sidelights?! and i drilled into my lights for tint LEDs, pfft :rolleyes:
¤± rev-o-lu-tion ±¤
mikester
Postby Project on Thu Jun 17, 2004 2:26 pm
The whole blue-light thing is a bit of a grey area - the regs apparently don't specifically say you can't show blue light, so police have to prosecute under construction & use, or try for impersonation of a police vehicle (but that one's only likely to stand up if the light is moving, i.e. on your wipers, or flashing).
The E-marked sidelight bulbs by Ring, etc, are kosher and just look a touch whiter than standard.
Al
Project
fiftyoneCL
fiftyoneCL
Postby mikester on Thu Jun 17, 2004 9:56 pm
i suppose its a bit boyracer like to change that stuff, i'm not one to talk, mines a christmas tree :lol:
¤± rev-o-lu-tion ±¤
mikester
Postby Max M4X WW on Thu Jul 08, 2004 12:09 pm
Just fitted some ring ultra xenon's and they are just as damn yellow as my standard bulbs :x
Postby Nilsson on Wed Nov 09, 2005 11:13 am
I´m prefering the Phillips Vision + 50%. They spend a very white light and are a lot better than the cheaper ones.
To be honest, I´m a big boi to that sh!t know...
Nilsson
Postby JamieFRST on Wed Nov 09, 2005 2:01 pm
Nilsson :I´m prefering the Phillips Vision + 50%. They spend a very white light and are a lot better than the cheaper ones.
Ive got them as well, very pleased with the results
JamieFRST
Keep It Tidy
Keep It Tidy
Postby t4 terrorist on Sun Dec 04, 2005 3:03 pm
these would be quite cool i a quad headlamp convertion.
http://www.xenondepot.com/product.php?product_id=37
if u have a spare 1000 quid kincking about
t4 terrorist
Postby RichardPoll on Thu Dec 08, 2005 11:58 am
have bought some bulbs for my scort that claim to be legal XENON for £7.99
take a look and tell me what u think
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
I have installed them but not giving off much lite, plenty immediately in front but not at a distance. Do toy think lights need to be realigned? anyone know how to doit?
- Now Drive a 1600cc Pug 306 GTI Spec
RichardPoll
Postby Max M4X WW on Thu Dec 08, 2005 2:41 pm
I have two mates with cheap ebay headlights, Cant see fook all and they emit a kind of grey light.
I had two cheap ebay 100w fog bulbs, nice and white, one blew, so did the other.
Postby Badgerboy on Thu Dec 08, 2005 2:56 pm
I'm running the Ring Sport Blue 100w bulbs, and have been for the last 3 years. Never had any trouble with them, including MOT's.
I've just ordered a new set of the Osram Power White 100w bulbs though, and a set for the driving/fogs. Hopefully they should perform quite well.
Badgerboy
Postby Big Walker on Sun Dec 11, 2005 5:28 am
Go to Halfords :D
At the moment (at least in my store) there is an offer on Super Brilliance bulbs (up to 50 % brighter) which is Buy 1 get 1 free which is basically two of them for either £12.99 or else £17.99 impending on which bulb it is
hope this helps some people :D
Lower than a snakes bollox
Each day I break my own personal record for the number of consecutive days I've stayed alive :)
Big Walker
Your car: Seat Ibiza
Postby jago25_98 on Sun Jun 25, 2006 11:48 am
What's teh brightest we can get without full beam though, without dazzling?
jago25_98
Postby Project on Wed Jul 12, 2006 2:10 pm
jago25_98 :What's teh brightest we can get without full beam though, without dazzling?
H4 Rally-spec 160/100W bulbs with an uprated (relay-equipped) wiring loom and properly aligned Ford-spec headlights (i.e. not the cheap Depo copies sold at motor factors').
Or the equivalent bulbs, with uprated wiring loom, in a pair of Morettes, but check for heat damage first as twin headlights have less free air to reduce bulb heat conducting into the light optics and melting things...! :oooh:
Project
fiftyoneCL
fiftyoneCL
Postby AGAR on Thu Jul 19, 2007 1:00 pm
Back from the dead:
I was wanting to have a read at your guide but the webspace isn't there anymore.
Could you either send me the info or post it here please?
Im looking to upgrade my headlights.
AGAR
Postby Max M4X WW on Thu Jul 19, 2007 3:33 pm
If you just want them a bit brighter and quite white just get some Ring SportzBlue bulbs from ebay, £11 posted.
Postby AGAR on Thu Jul 19, 2007 6:06 pm
Max M4X WW :If you just want them a bit brighter and quite white just get some Ring SportzBlue bulbs from ebay, £11 posted.
Interesting 8)
What sidelights did you use to get rid of the yellow colour?
I assume the Ring Sportzblue bulbs are your dipped/full beam lights.
I remember you posted a topic about them once.
AGAR
