Heatshield for Between T3 turbo and Starter Motor
11 posts • Page 1 of 1
Just a quickie to see if anyone else has had one made/adapted for their fiesta turbo as because they are next to each other the heat from the turbo is causing the car to cut out!
Any help appreciated as i was built to drive cars and not fix them
- ET
i am going to look into making one for my xr2i out of steel first and see what it is like, will let you all now if it goes ok , just got to get the time, dont like the heat sheild bags they got for them rather have a nice shiney sheild
- White2i
- j7aoc
Well.. i've been in pondering about this earlier.. and i tried to fix it like below..
Most of the heat that will damage your starter isn't directly from the turbo, but from the downpipe that goes just past the starter.
I bought myself a ERST starter heatshield.
Bought myself a brand new 1.4kW starter from an escort 1.6 16v
Why this starter.. and not one for a FRST or ERST ??
Well.. that's because this is a reduction starter .. and can cope with the heat a wee bit better then the ERST/FRST one.. appart from the initial current (A) it uses is lower compared to the ERST one.. so less stress on the wiring to the battery (which is in the boot).. and the 1.4kW makes it fly when starting (-: in stead of the whining noise..
Fitting the heat shield ....drilled some holes to fit the fixing material (cause the starter is slightly different to the ERST starter)
Cut away some other parts that were in the way of fixing the electrical bits..
Made sure the heat shield wasn't ratteling
Here's the result.
Here's the result.
- Jur
i have just done a t3 conversion and not had any problems yet would u advise to fit a heatshield and wrap the downpipe also cheers
- fiestaturbopete
- j7aoc
