Help Electrical Problem :(
Postby nuno almeida on Wed Nov 27, 2013 9:01 pm
Good afternoon I have a Fiesta 1.8 16v XR2i, I have a problem with the car since I bought it, the pointer when I turn the ignition temperature will soon to the middle of the display, and pointer gasoline rises around 2 mm when I turn the speed heater the lights and when I click the button to raise the glass, and the battery light comes on but not too strongly when I do these processes,
    And when I click the button to raise the glass spins the pointer rises eg from 3500 to 4000.
    The battery is 2 years, the water temperature sensor is new the alternator charges the battery at 14.20 volts. Already checked wire to wire and never know what's going on with the car electronica.
Have any of you guys know me explain this phenomenon?
Help: (
nuno almeida
Your car: XR2I 16V
Re: Help Electrical Problem :(
Postby jayrs on Wed Nov 27, 2013 10:23 pm
Sounds like an earth fault to me, I would check and clean the earth point on the steering colum ( behind the pastic under the ignition switch)
I would also check and clean the earths on the battery
