Help hav i blown my sub or amp?
8 posts • Page 1 of 1
Playing music last nite, sat at the traffic lights and put on the 33hertz track after 20 seconds the sub cuts out, oh i said i probably blown a fuse or summat happened b4.
First thing in the morning i pop open the bonnet to check the fuse, fuse is ok. hmmm???
The light on the amp is not comming on when i turn the headunit on. Buts
Check the cables are not damaged, nothings damaged.
its working bcoz its running my 4 channel amp too.
Checked the fuse on the amp thats ok
Im running a power cap, thats on and showing voltage
Im sure it cant be the earth cud it? Ive sanded down to bare metal and tighted the screw for the earth?
Its a VIBE sq 12 active subwoofer. Can anyone help me?
- butler_29
Ditch the power cap, it drains loadsa power from the battery and may have caused the problem when you started increasing the volume!
Also what amp is it as some have an anti-clipping sensor which shuts the amp off when the volumes too high
- diablosvy
well i sent it back to mcr audio in manchester. He said he'll today test it, then fone me probably with a replacement
wen buying a new sub is it recommended to play it at half the volume for 30 hours or so? not just wack it 3/4 on the gain and 26 on the headunit on an alpine?
ta ppl
ta ppl
- butler_29
butler_29 :well i sent it back to mcr audio in manchester. He said he'll today test it, then fone me probably with a replacement
ta ppl
Ideally you want to get the amp scoped, and not just wack the gain up becuase it induces clipping that goes for the headunit as well
Its a fallacy that you have to break things in...things are designed to go from day one
- diablosvy
nice to know, well when i get my replacment shall i play the sub a half of the gain or 1/3? im gonna get two subs as well. Is that same with all speakers inc comp, coxial, mids playing at half volume.
cheers Anil
cheers Anil
- butler_29
butler_29 :nice to know, well when i get my replacment shall i play the sub a half of the gain or 1/3? im gonna get two subs as well. Is that same with all speakers inc comp, coxial, mids playing at half volume.
cheers Anil
Yea it is the same, TBH dont take this as fact but id say volume up 2/3, then turn gain up until it starts to distort or nomore than say...2/3, but as I say unless its scoped you really dont know
HTH
- diablosvy
