help identify brakes
Postby whitedragoon on Sat May 11, 2013 6:55 pm
Hello, i have front brake conversion and want to get new pads and discs but discs bigger than seller told me and now im confused which model they are taken from. I have 260mm discs and everything in the picture. Is it really rs turbo calipers?
whitedragoon
Your car: mk4
Re: help identify brakes
Postby mikeymikeyp on Sun May 12, 2013 10:41 am
turbo pads are the same mate prob rs2000 calipers if its 260mm
mikeymikeyp
Postby Andrea on Thu May 16, 2013 1:46 pm
The SportKa, MK5 Zetec S and 1.4 & 1.6 Puma all have the same brakes which have 260mm discs, so I wonder if they are what the calipers are from?
Andrea
Your car: Ford Ka Turbo / MK5 Fiesta
Postby Smo on Tue May 21, 2013 11:30 pm
From memory, if the piston size is 60mm, they could be anything from Series 2 Escort Turbo to Sierra, Granada, etc to MK5 Escort RS2000/XR3i 130PS.
If they're 54mm, then it's likely to be one of the above that Andrea mentions.
I run S2 calipers with MK5 Zetec S discs (which I believe are the same as a lot of MK6 Fiestas, Focus, etc)... They're 22mm thick. Previously I ran RS2000 discs which are 24mm thick and about twice the price!
Your retaining clips in the photo are different to mine, so they could well be MK5 Zetec S, Puma, etc or similar?
Smo
Postby jonyb4 on Wed May 22, 2013 11:32 pm
i recognise the shape on the middle of the caliper.. theyre Escort RS2000
its worth noting.. that only the later pumas had 260mm brakes, earlier ones had 240mm like mk3 fiestas, even the 1.7
Postby whitedragoon on Fri Jun 21, 2013 9:58 pm
Many thanks for the responses. Still not sure which brake discs are the right ones. Got brake pads from RS turbo but theyre slightly smaller in width. I believe i will go for getting all front 280mm upgrade. :)
whitedragoon
Your car: mk4
Postby jonyb4 on Sat Jun 22, 2013 12:19 pm
280s will be too big
RS2000 brakes use 260mm~ discs (258mm i believe)
