Help! Inner CV removal from gearbox
Postby ben47771 on Sat Feb 02, 2013 6:38 pm
I am changing a drive shaft on drivers side on my lsd ib5 gearboxed frst taken shaft its self out, but inner cv has poped out of spline cup. Now i cant get it out of gear box it is soldly wedged in there i have tried banging out leavering out etc but no joy and really bugging me now! Any body got any ideas?
Ben
Old Fords Never Die; They Just Get Faster!
Drives: Fiesta RS Turbo, Zetec turbo. Ford Transit Crew cab tipper 2012. 2005 Audi A4 1.9 TDi 130 Sline
ben47771
Your car: 1990 Fiesta RS Turbo
Re: Help! Inner CV removal from gearbox
Postby andymac on Sat Feb 02, 2013 6:58 pm
Levering out normally does trick, they can be ridiculously tight (and others I've pulled out with a good solid tug by hand!).
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby ben47771 on Sat Feb 02, 2013 7:07 pm
Yeah i have done plenty of them in the past. Normally find they leaver straight out with little effort if it dosnt just pull out by hand but this one is a bast**d. Never known anything like it. I guess i just have to carry on and it will budge at some point!
Cheers for the advice
Ben
ben47771
Postby Tweek on Sat Feb 02, 2013 8:27 pm
You've probably already tried it but I used a fat chisel behind the "cup" and smacked it with a lump hammer, as for the other one, I used the chisel as a lever since you can't get in behind it, then again whacked the chisel. Popped eventually!
Your car: VW Golf GTD
Postby DanFraser on Sun Feb 03, 2013 1:02 am
I've used a 3ft crow bar on one side with a serious amount of effort involved.
DanFraser
Your car: Ford Fiesta SI 1.6
Postby reithy on Tue Feb 05, 2013 8:15 pm
Normally use a crow bar, and out they pop
reithy
Postby mikeymikeyp on Tue Feb 05, 2013 8:41 pm
have you left it in gear ,that wouldnt help lol can u not just split it from the boot
and like everyone else sometimes they pop no problem other times its the old hammer n chisel
mikeymikeyp
