HELP ME PLEASE!!! lol
6 posts • Page 1 of 1
yellow people, iv got a 1.6 si mk3.5 fiesta, with 15" (195) wheels and dropped it 35mm. (G-MAX SPRINGS)
the bad news is that SHE still rocks side to side quite alot round corners!! im not a happy bunny.
any advice on how to over come the problem, like to get uprated antiroll bar links, or ali-ment kit??
any help will do, cheers do1
- wantmorepower
get some uprated shocks. just having the springs will give it a crap ride as the springs will move about in the standard shocks.
after that if you want even better handling, get a front anti-roll bar and maybe a strut brace too.
pete
pete
- musicdrummer42
Yep you really want uprated shocks too
Now Si's come with a front ARB as I recall, but I dont think anything at the back?
Strut braces are also excellent and firming up the bodyroll, but I think in your case you should start with the shocks. Also 35mm is not THAT much lower than stock so dont expect miracles.
- Stoned
Stoned :Yep you really want uprated shocks too
The Si 16v has front and rear ARB's. Shouldnt roll about too much though. mine's got uprated shocks+springs and has hardly any body roll.
you can get poly bushes for the ARB's that might help a little bit
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
Body roll isn't bad! A little bit helps you out a lot, rock hard suspension is onlt of any benefit on the track
cheers people for the reply, i have upgrated the shockers. the supesion is fine for up and down useage,
( hard, u can feel everybump plus exhaust grounds out on speed bumbs!! not good got to look at that! )
but corners rolls abit too much for my liking. mates car is better handling into corners.
nevermind, ill see how that goes and buy a strut barce
cheers, ill play around with ideas
- wantmorepower
