help needed running problems
2 posts • Page 1 of 1
Hi I have a fiesta rs turbo I bought a wile back it was running bad wuldnt revup at all so I have just replaced the loom ecu and map to ofab wen I got it all wired up it started and then just cut out and that's all it wild do so I changed the co pot and now it idels perfect but won't rev past around 2500 3000 it just sits around there with foot to the floor just popping any ideas as im starting to get fed up with it
- antn0585
Re: help needed running problems
ok guys hers what its had
its had new
plugs
leads
coil pack
crank sensor
tps sensor
map sensor x3
co pot
loom
ecu
turbo
all earth cheacked
done a continuity test aswell
all plugs are jet black so its over fuleing if im slow on the revs it will rev up same if im on and of the thottle fast over and over it will rev but if i just rev it it wont go past 2500 tried ajusting the fpr to 3 bar no change also set the co pot in the middle no change so if anyone has any ideas id be greatfull as im about to give up and sell it as nothing seams to work
its had new
plugs
leads
coil pack
crank sensor
tps sensor
map sensor x3
co pot
loom
ecu
turbo
all earth cheacked
- antn0585
