Help please fan not working.
7 posts • Page 1 of 1
Hi there i have a fiesta xr2i 1990 1.6cvh and the fan wont work. The temperature needle reaches just touching red but fan doesnt kick in. The fan itself is fine as i bridged the fan switch and the fan kicks in. It wasnt working before i got the car and i replaced the fan switch sensor and still no luck, this is the sensor i got.
http://www.ebay.co.uk/itm/380471018392? ... 1497.l2649
it is a white colour switch and the one i took off is blue should that make a difference?
Any ideas what else i can try. Just a separate issue but the nothing of the boot stuff will work i.e wipers boot release although there is power going to switch.
- Farooq
Re: Help please fan not working.
clean the contacts on the slam panel of the boot and the colour does matter i think the one on the inlets the white one but im not 100%
- mikeymikeyp
Look at your ignition relay and see if it has melted the fuse box contacts
No1 suspect for your fault
- Pastieman
- Your car: Mk3 Fiesta Rs Turbo
Thanks for.reply would car not start if it was ignition relay? Do you know what relay is for ignition?is there anything
Else I should.check?
- Farooq
No it can just stop the fan working, boot pop etc, fuel pump etc... Depends what pin has lost contact on the relay !!!
It's the green relay behind the fuse box!!!
Also check out the sticky in the technical/fault forum there is more information there if you need to find location of it
This has happened on a few of my old frst's and I think it has started on my newest one lol
- Pastieman
Thanks buddy will have a look
- Farooq
Right took of relay and two of contact pins were a light brown colour. Cleaned up contact and plugged in and fan stil not kicking in. The actual contacts on the board and plastic are fine.
When i press the boot release the relay buzzes. f**cked relay? If it is, is the green relay from any fiesta mk3 be suitable or do it need to be a xr2i one?
Also the fan temperture sensor switch was replaced but it turns out the sensor is from a air con car could that be an issue too?
- Farooq
