help please mk3 zetec conversion
1 post • Page 1 of 1
hi i am looking to put a 1.8 zetec from a mk6 escort si into a mk3 1.1 fiesta shell. i have the esocrt complete so wiring and ecu ant a problem. i have been told i need the engine mounts and drive shafts from a si fiesta. but i still need to find out a bit more info. can i use the 1.8 escort gearbox? if not what box can i use and with witch flywheel and clutch and is any modifying going to be needed to chassis to fit the lump in? also will there be enough room for the inlet manafold, as i have put a 2ltr in a mk3 before and we had to use the 1.6 manafold because the 2ltr one would not fit in? thanks and i hope to here back so can get the conversion under way. ian
- ianhayle
