HELP PLEASE!!
HELP PLEASE!!
Postby :: blade :: on Wed Jun 13, 2007 5:25 pm
my amp keeps blowing its inline fuse near the battery, gone through 3 of them now :x whats do you recon is up with it? ive checked the connections and all is well, so what could it be??
:: blade ::
Postby Ollybee on Wed Jun 13, 2007 5:28 pm
Is the fuse of the the correct rating?
Is your amp buggered?
YRN Thread - yrn-vt151433/
Ollybee
Car: 1996 Ford Fiesta Quartz
Postby :: blade :: on Wed Jun 13, 2007 5:35 pm
yea all were F80A fuses, the amp was fine yestuday, and has been fine and was using the same fuse for 3yrs, and its popped 3 in 2days, ask HCS PIMP, put it on the other night for him, and was fine :-? turned the amp down again after that
:: blade ::
Postby martyc on Thu Jun 14, 2007 10:26 am
damaged cable, buggered amp internals, dodgy earth (check battery to chassis earth too). try a different amp to see if that changes things. and remove the power line and see if there is any chafing/damage.
martyc
Postby enve19 on Thu Jun 14, 2007 12:08 pm
I went through two fuses in two days last week.
My problem seemed to be the ground. It had come loose from the lug on bodywork. Put a new lug on there and its been ok since.
Check the ground to ensure you have a good connection either end.
enve19
Postby :: blade :: on Thu Jun 14, 2007 7:32 pm
cheers for the replys guys will check it at the weekend
:: blade ::
Postby :: blade :: on Wed Jun 20, 2007 8:08 pm
ok, the amp has stoped blowing fuses now, and the green light stays on, on the amp :D but 1 problem, the subs dont make any noise :( dunno what it, is, checked all the wiring and all is A OK, would my subs have blown??
:: blade ::
:: blade ::
