help smokey jo, need diagnosis please
13 posts • Page 1 of 1
check out my car. this was taken today and has been like this for a week or so.
https://www.youtube.com/watch?feature=player_detailpage&v=ZIzwtaTDvMI
i can tell you that it is leaking oil from the rocker cover as far as i can make out.
i need to know what this is, guess that is it burning oil as it sticks of oil when smoking.
only smokes when the car has been sitting for a few hours and as you can see smokes once warm and goes away after 3-4 mins.
please help.
please help.
- xjtaggedx
Re: help smokey jo, need diagnosis please
Turbo oil seals? Does it definanitly go away?
- reithy
The other thing is valve stem seals
- reithy
thank you sir. i will try to replace both of them. is it a big job? money wise? and yes sir it goes away
- xjtaggedx
also any idea where i can order the parts from?
- xjtaggedx
Stem seals any motor factors will sell them and they cost around £7 but you will need the tool that lets you remove them without removing the head. It will take about an hour of your time. If its the turbo seals then you are looking at a turbo rebuild. It will depend on what turbo you got if its a t3 then around £250 for a rebuild but if a t2 your looking at £350. The t2 is notorious for wearing the shaft and once been rebuilt once you will need a new shaft because an oversize seal cant be fitted. If you have a t2 I would suggest doing a t3 conversion not only will it be cheaper but you will gain some power also
- rsturbonutter
- Your car: Fiesta RS turbo
I have the standard t2. Not looking to go t3 as I would have to upgrade other parts right? I may go turbo technics and get them to do a hybrid for me?! For about £400-500. And the need a new shift. Don't know what that is. Thank you so much so far you have help lots. I guess I do the stem seals first.
- xjtaggedx
Smoke on the overrun like that is classic turbo seals, not saying it can't be stem seals.
Worn stem seals let oil seep into the combustion chamber overnight, so if it is those then the car will usually smoke when started from cold.
That is what is happening sir. Smoke on start in the morning and after 5mins is all fine
- xjtaggedx
As said in your other post then mate sounds like the stem seals
- rsturbonutter
so had an oil change, valve stem seals, oil filter and rocker cover gasket changed, still smoking. i should ad that this all started to happen shortly after i had my exhaust manifold gasket changed by POWER ENGINEERING. could they have focked something?
- xjtaggedx
Are all your breather clean and blockage free other than that I am afraid its leaning towards your turbo
- rsturbonutter
i mean could the breather be a cause for oil leaking in somehow, i am sorry but my knowledge of cars is limited. I just know that it is becoming worse and worse. if it is the turbo any idea how and where i could pick up a new 1? or does this option not exist? other than that money is also limited what would be the best option for me. thank you for all your help.
- xjtaggedx
