help!!
9 posts • Page 1 of 1
help!!
Lowering Si 1.6
Whats needed as have just spoken to some gammon slipper at my work who thinks he is the man with cars!! Paxo Driver!!! Says all
he says that all i need are springs to lower it, but im sure you have to have shocks also afterwise wouldn't the spring just slip out!?!?
and also there are specific springs for certain cars you can't just put some random springs from a bmw onto a fiesta can you!!?!?
very confused and who best to ask than the Ford Fiesta faithful!!!
1994 Fiesta Si 1.6 16v
- LeedsOnTour
He is right mate, you can use just springs. Your right too though as you do need specific springs for cars.
All you do is swap the springs over.
However it's generally better to use a sping/shock kit as chances are your shocks will be tired so lowering will most likely finish them off. Doing this will be better for handling anyway.
HTH mate.
HTH mate.
- XR_Craig
Can't comment on the Si as teh damper rates may well be different but on our 2i we found lowered springs with new (NEW being the key word) standard shocks gave very good results. Even on a 55mm drop we had no problems with the spring coming out of its cup.
thanks for the info ppl!!
As i havent actually doen any lowering or cars in my life will prob get shocks and spirngs just need to get bit of moeny together!!
Should make car look alot better as looks bit like a monster trunk at the moment!!!!
- LeedsOnTour
Well My Si has broken 2 shocks alread being lowered 35mm lol.
I think one of the best you can get is lowering springs and the front and coilovers/shocks and springs on the back, the front of the Si's handles pretty well as it is, bit of understeer but its a fwd car so u know.
- javablu
Flip2k3 :Well My Si has broken 2 shocks alread being lowered 35mm lol.
flip what wheels you running your Si on?!!
As i have a couple of chices on how much to drop it!!!
tompeteRS
2 fat birds in the back of your Fiesta also works quite well!!
So is you girlfriend and ex ready for a ride are they!!!
Not bad idea but would prob be hard to get them out of a three door Si!!!
Loads of wd40 and lard required!!!
- LeedsOnTour
Coilovers are really not much use on a road car.
How on earth did you manage to break a shock? The only way I can see that happening is the use of sub standard shocks or abuse far beyond fast road driving
