Help!!!!
Help!!!!
Postby fastfezz on Thu Jul 18, 2013 7:09 pm
Hi i have a 1989 fiesta mrk3 5door
i removed the rocker cover and there is white gunk on about 3-4 of the rocker
i know this means the head gasket need replacing but how easy is it to do and what do i need to do it
fastfezz
Your car: ford fiesta
Re: Help!!!!
Postby AW0L on Thu Jul 18, 2013 8:35 pm
it doesnt always mean its the head gasket...
but if you have a push rod engine, its very easy, once done you will need to re gap the rocker arms, there are several guides here somewhere on how to do that, otherwise its very tappy
AW0L
Re: Help!!!!
Postby MB7201 on Thu Jul 18, 2013 8:46 pm
As above, if used for short journeys it's common to get a build up.
MB7201
Your car: Fiesta lx
Re: Help!!!!
Postby FRSJON on Thu Jul 18, 2013 10:05 pm
MB7201 :As above, if used for short journeys it's common to get a build up.
100% agree. ive changed head gaskets for people that insisted after finding this and nothings been wrong with them :lol:
FRSJON
Help!!!!
Postby willowandmikey on Thu Jul 18, 2013 11:53 pm
They are prone to it I walked away from a mk3 because it had loads of gunk but had only done 11k miles and kicked myself for it check for other symptoms like water in the oil and the header tank
willowandmikey
Your car: ford fiesta xr2i 8V
Re: Help!!!!
Postby AW0L on Fri Jul 19, 2013 5:11 pm
willowandmikey :They are prone to it I walked away from a mk3 because it had loads of gunk but had only done 11k miles and kicked myself for it check for other symptoms like water in the oil and the header tank
lol i tried to sell one that had the buyer think the same... he said to me "you got a lot of problems there, good luck... "
but mine was only 87k
AW0L
Re: Help!!!!
Postby fastfezz on Fri Jul 19, 2013 8:19 pm
thanks for the advice
but now ive looked at the coolent hoses and it looks like water and oil have mixed somewhere
i found it in the coolent tank and their hoses?
thanks
fastfezz
