Help with Fiesta mk3 Brake upgrades
7 posts • Page 1 of 1
Hello there,
Im pretty new to this site, so please excuse any stupid questions.
I tried to search the forums but had no luck in finding an answer.
I have a mk3 Fiesta , 1.3L version. I have recently put 15" alloys on.
Im lookign for a brake upgrade as my mechanic said my brakes are in FINE condition, just not good brakes in general.
Any advise on what I can do. Im guessing new pads and discs up front, but any recommedations?
I've seen there is a rear conversion to discs but it's very pricey, and wondering can you just upgrade the fronts?
Thanks,
Scott.
Thanks,
Scott.
- funkdude2
If you're not going to go mad with your engine I would recomend a set of vented discs and calipers from an Si/XR or RS if your discs are currently solid. These should bolt straight up with no messing and when used in conjunction with a quality pad like Mintex 1144 or Ferodo DS2500 with fresh DOT4 fluid should be a vast improvement. You don't need discs on the back fella so don't even start to worry about that.
thanks lovely, thanks for your reply.
you mentioned new discs and calipers, and quality pads with new fluid.
Coudl you point me the right direction where ot get these as dont want to buy wrong things.
Whats the cheapest option, could I simply get quality pads with vented discs? do i need new claieprs?
How much would all the above items cost.
Thanks a lot for your help,
Scott.
Scott.
- funkdude2
You will need to change the callipers to change from solid to vented discs as the vented disc is thicker do check you don't already have vented discs though as I've seen a couple of 1.3's with them
Callipers £40 2nd hand (parts wanted/for sale on here or any breakers yard)
Discs £70 new (any motorfactors)
Pads £40 new (Adverts in Fast Ford/Performance Ford)
DOT4 £10 (any motorfactors)
ok great. are the calipers a certain size.. or can i just ask for si calipers?
Concerning the discs.. could you recommend some vented discs.. or are standard si ones fine? do they come with the calipers to suit? And what size shall I go for, or is there a standard size
Concerning the pads... do i need the pads made for xr2i? or just type that part number into google.
I am sorry about my confusion, not to hot concerning brakes with a car.
Scott.
Scott.
- funkdude2
