Help with Mk3 Clear Side Repeaters
Postby dirtydan on Sun Nov 25, 2001 4:48 pm
i wanna fit clear oval side repeaters on my mk3 1.1, and I know you can not buy them to fit straight on, so can anyone tell me how to fit them [ERRR] i cant get the bulb holder into the repeater and im not sure how to take off the old holder to replace with the new one, which came with the repeaters. Wats the best way to fit them ?
dirtydan
Postby Project on Mon Nov 26, 2001 8:06 pm
You can buy them to go straight on. Look in Fast Ford or Performance Ford mag.
Al
Project
fiftyoneCL
fiftyoneCL
Postby MadcatCraig on Mon Nov 26, 2001 8:18 pm
Mine are universal ones ! i just chopped the wires from the original bulb soldered them to the universal wires, bound them with insulation tape and they have sticky stuff to stick on !
Al's ure unlce they look the muts, flash orange and are legal too :grin:
Failing that you can find anyother way to join 2 pieces o wire ! soldering allways best option methinks !
MadcatCraig
BANNED SELLER
Postby festajon on Mon Nov 26, 2001 10:17 pm
Look in the carnoisseur catalogue. They make oval ones with the same screw n'lock type style as the square ones, rather than arsing around inside the wing to get em out or peeling bits of sticky off your car when u have to remove 'em. They are £20 quid and i'm sure that other companies do 'em for cheaper but this was the first one i found.
Hope this helps
festajon
Postby TJ on Tue Nov 27, 2001 3:56 pm
remove the arch lining unclip the original ones, then unscrew the bulbs.
Then repeat in reverse mode replacing original ones, with new ones. Easy peesy.
TJ
Postby Steveboy on Thu Nov 29, 2001 5:58 am
I bought my self a set of universal ones.
Had to do a few mods so i got the old leatherman out (Coolest tool ever :grin: ) I hacked all the silly wee bits off. Got some of that dbl sided tape for the number plates and stuck it on the indicator. Then tried to fit the bulb holder :grin: :grin:
No probs with them :smile: :smile: :smile:
Concours White FRST resto on going......
Steveboy
Postby dunster on Sat Dec 01, 2001 9:59 am
i did it well easy. i got a universal set from halfords for £18 and you just twist the old ones off and stick these on with the pads supplied. honestly, if i did it then it must be easy.
dunster
