Help - Zetec Throttle Bodies
Postby SimonT on Sat Feb 22, 2003 9:52 pm
Need a fav off of you 16v zetec owners. (especially RS1800 owners)
Can you take a pic of your throttle body like this:
It would be very much appreciated.
ST
Too old and too bald.
SimonT
Your car: Fiesta Zetec S TDCi
Postby chrissi16v on Sat Feb 22, 2003 10:26 pm
its to late to take a pic but mine the same as that 1
chrissi16v
Postby SimonT on Sat Feb 22, 2003 10:30 pm
what have you got? 16v 2i or RS1800?
SimonT
Postby chrissi16v on Sat Feb 22, 2003 10:31 pm
1.6 sadly
i think them bits r the same on the 16v 2i as the si but on the rs1800 u have a biger opening
chrissi16v
Postby unknown_user on Sat Feb 22, 2003 10:32 pm
mine is not like that, the inlet is bigger, and the sensor is round the other war (the clip on bit faces other way) and it s a 2L zetec
unknown_user
Postby SimonT on Sat Feb 22, 2003 10:33 pm
I have a pic of the 2.0 one - but not of the RS1800
SimonT
Postby chrissi16v on Sat Feb 22, 2003 10:36 pm
i think the 2L and the rs1800 part are the same
chrissi16v
Postby SimonT on Sat Feb 22, 2003 10:37 pm
I dont think they are. thats what im trying to find out!
ST
SimonT
Postby chrissi16v on Sat Feb 22, 2003 10:39 pm
yep i think the opening is the same but on the 2L the throtle cable mount is a different way so is the sensor thing [ERRR] it lays down on a mondeo im sure thats the dif
chrissi16v
Postby unknown_user on Sat Feb 22, 2003 10:45 pm
well my 2L tb has the clip facing the other way, then i had to change the mech over from the 1.6 tb i had over to my 2l one as the mech for the 2l was plastic, and didnt fit properly!
in that photo the TB looks like a 1.6 one but it may just be the photo!
unknown_user
Postby chrissi16v on Sat Feb 22, 2003 10:48 pm
yeah ive got a 1.8 one from a mondeo and the mech is plastic and a dif way round with it being mounted dif on the mondeo but the opening is the same as my 1.6
chrissi16v
Postby Project on Sun Feb 23, 2003 5:29 am
1.6 finis 7221346
1.8 finis 7221345 - might be physically identical but the part nos are diff.
Project
fiftyoneCL
fiftyoneCL
Postby unknown_user on Sun Feb 23, 2003 10:33 am
why did you want to know? u can fit the 2L throttle bodie by swapping bits over, anoyying mut it can be done
unknown_user
Postby SimonT on Sun Feb 23, 2003 3:19 pm
I just want to be able to say its got a rs1800 tb :)
SimonT
Postby mike_c on Sun Feb 23, 2003 6:50 pm
this might not help too much, but...
a 2l mondeo TB has a larger butterfly valve than that, (i.e. the inlet doesnt narrow on mine),
you can also keep the plastic mech bit rather than swap the 1.6l one over, just mod it slightly (cut little useless nobbly bit off from the rhs :oooh: ) and check it doesnt obstruct hoses behind it. I found it had a much stronger spring than the 1.6l TB
i made my own throttle cable mounting bracket, i've got a pic but need to get it developed first :rolleyes:
mike
mike_c
Postby unknown_user on Sun Feb 23, 2003 8:56 pm
i swapped the mech across, ill get a pic when my usb devices work god dammit!
unknown_user
Postby SimonT on Mon Feb 24, 2003 10:44 pm
Chum - GO TAKE A PIC OF YA THROTTLE BODY!! :lol:
ST
- and would the one from a Escort 130PS fit? Is it a mondy one or a fiesta one?
SimonT
Postby Project on Tue Feb 25, 2003 1:41 am
Escort 130ps same as Fiesta.
Project
fiftyoneCL
fiftyoneCL
Postby SimonT on Tue Feb 25, 2003 11:54 am
Al -
Just found out that the Escort 1.8 115ps is the same as the 1.8 Mondeo?!
Could the 130ps escort one be the same of the 2.0 mondeo?
SimonT
Postby fiestakingfisher on Tue Feb 25, 2003 12:45 pm
My car ran quite differently with the 2,0 and RS1800 throttle body.
Si, where is the part number on the tb??? lol
Will post a pic of it in a sec.
fiestakingfisher
PurePower
PurePower
Your car: Fiesta 2.0 Kingfisher, BMW Z4
Postby fiestakingfisher on Tue Feb 25, 2003 12:56 pm
fiestakingfisher
PurePower
PurePower
Postby mike_c on Tue Feb 25, 2003 1:16 pm
which one's that?
doesn't look like my 2litre one from a mondeo
mines from an auto, but it wouldnt make any diff would it?
mike
mike_c
Postby chumkila on Tue Feb 25, 2003 1:19 pm
RS1800 TB according to Lou.
Postby fiestakingfisher on Tue Feb 25, 2003 1:19 pm
Thats a RS1800 one.
I used it on my car when it wasn't putting enough fuel in to use the 2.0 tb.
fiestakingfisher
PurePower
PurePower
Postby SimonT on Tue Feb 25, 2003 1:25 pm
Lou - that is not a RS1800 TB!! Im 100% sure!!
It looks exactly the same as the xr2i/Si one
SimonT
Postby fiestakingfisher on Tue Feb 25, 2003 1:28 pm
Martin (MK) got it off ML Developments as a RS1800 tb, and it came with the RS1800 ecu thats running my car... :s
fiestakingfisher
PurePower
PurePower
Postby SimonT on Tue Feb 25, 2003 1:32 pm
Lou - im sure thats not a RS1800 throttle body. Id stake my car on that!
Might be worth you checking your ecu....
SimonT
Postby andymac on Tue Feb 25, 2003 1:32 pm
Whats the finis part code on that tb Lou ?
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby fiestakingfisher on Tue Feb 25, 2003 1:39 pm
there's 928f-9u538-ca on the plastic bit on the side..... not sure if thats the tb tho
other numbers on it aaaaare.. 5 42 then a ford logo, then 938fka
or 921202
fiestakingfisher
PurePower
PurePower
Postby Project on Tue Feb 25, 2003 2:08 pm
The throttle body in that picture is a 90PS one Lou.
Project
fiftyoneCL
fiftyoneCL
Postby Project on Tue Feb 25, 2003 2:17 pm
Si,
All Mondeo 1.8 engines seem to be rated at 115ps.
Project
fiftyoneCL
fiftyoneCL
Postby SimonT on Tue Feb 25, 2003 2:25 pm
cheers al.
Im thinking of just going straight for a 2.0 mondy one - but ill settle for a RS1800 one if i can...
*sets off towards chum's house with tool box in tow!!*
SimonT
Postby chumkila on Tue Feb 25, 2003 2:28 pm
pimsle!! Si i MAY be passing round ur way this weekend. I'll let ya know.
Postby SimonT on Tue Feb 25, 2003 2:30 pm
wicked Chum!
Im up in Manchester saturday morning but ill be back sat afternoon through till sunday.
Charice in the place too! :D
SimonT
Postby chumkila on Tue Feb 25, 2003 2:39 pm
:lol: im not sure when i'll be passing thru yet as ive gota visit the airport at some stage saturday (hohpefully mornin) and if all goes well i'll be around til late sunday. :)
