Hi-fi knackered?
Serious non-car discussion - computers, films etc. Pointless posts will be removed.
Hi-fi knackered?
Postby 16Valver on Wed Mar 24, 2004 1:43 pm
Attention all electronics experts! My knowledges stretched to GCSE and thats it!
My hi-fi's been acting rather odd lately. It's an Aiwa micro system I've had for a few years (cost about £200) which has never given me any problems before. But now it keeps switching itself off, then sometimes it comes back on after a few seconds, sometimes a few minutes, sometimes not at all - not even the standby light comes on even though its still plugged in.
I've had a look at the plug, and checked the fuse which is ok. I also took the hi-fi apart and cleaned out the dust, and noticed there was a fuse in there which wasn't broken but looked a little darkened in the middle.
Any ideas as to what it could be, as I don't really wanna buy a new one when all thats wrong with this is the power connections :-?
16Valver
Postby Sunil_FiestaRS_16V on Wed Mar 24, 2004 4:04 pm
could just be a dry solder try heating up any slodering u can see.
this was the case with my tv remote it wud sumtimes work and sumtime wudnt then went alltogether so i just resoldered everything and it works fine now.
its worth a try u have nothing to lose
Sunil_FiestaRS_16V
Location: Slough. 2.0 with Raceline head, Raceline cams, T.E Exhaust manifold, and more...
Postby 16Valver on Wed Mar 24, 2004 4:29 pm
cheers Sunil. Trouble is, theres a whole lotta PCB in there! is there any way to detect a dry solder without re-heating the whole lot!
16Valver
Postby Ollie on Wed Mar 24, 2004 4:33 pm
Look primarily at the power circuits, trace them from where the mains enters the board and check nothing is loose. The other option is that it could be a dodgy power switch. My stereo turns itself off something and I just have to poke the switch a few times before it will stay on. :lol:
Ollie
Your car: VW Polo SEL 1.6 TDI
Car: 1988 Ford Fiesta XR2
Postby Project on Thu Mar 25, 2004 5:26 am
If it's got a IR remote, put some tape over the receiver for a few days and see if it still happens - you sometimes pick up random IR radiation which turns stuff on and off....
Otherwise, definitely replace the fuse (with one of the same rating).
Also check for short-circuits in the speaker wiring as this may be tripping a thermal cut-out on the amp circuitry.
Al
Project
fiftyoneCL
fiftyoneCL
Postby 16Valver on Wed Mar 31, 2004 11:03 am
just an update...
I took it to a respectable local independent shop where the guy's had it apart, says all the outputs are ok and he thinks it's the mains transformer, quoting £40 or thereabouts. Does that sound about right? I've had a look at some new units - Makro's got a few ok ones in around the £120 mark but I think I'll get the old one repaired.
16Valver
