hitachi iscv remote
4 posts • Page 1 of 1
hitachi iscv remote
as above how do i no if i have 1 and not the webber.does any body have a pic of it.and what other fords can i get these hitachi iscv remotes from i have an xr2i cvh h reg mk3 .thanks
- MK4 Rick
- Your car: Mk5 Fiesta
If the ISCV is mounted on the air filter box it's the Webber. If it's mounted on the bulkhead it's the between setup while Ford sorted things out. If it's on the left hand side of the TB then it's the Hitachi. To swap to the Hitachi valve you will need the upper part of the inlet fannimold a 2mm hole in the bottom half of the throttle butterfly and iirc the ECU from a Hitachi equipped car as well
hitachi iscv remote
mines located on the throttle body.so is that the good on.its on a h reg mk3 fezzer 2i cvh
- MK4 Rick
