HMMM questions?
9 posts • Page 1 of 1
HMMM questions?
Hello, does nayone know wether i could and K&N air filter for me 1.1 HCS engined fiesta?
Plus if i got a exhaust is it better to get a WHole thingmy or just the backbox because i plan to get an engine conversion and was wondering if i could keep the uprated exhaust of the old engine and swap it straight to the new engine.
RuM
RuM
Choobe de daaa, chaboo da dee
- rumtickler
Im sure you will get a K&N filter...........
as for exhaust, your better to get the whole thing.............including manifold. That way you will get the full benefit.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
yes search!
as for zorst dont waste u money on the hole thing and ull be lucky to find a manifold that u will get anything extra form without paying big money, and the second u change the the engine it will be useless
and uprated engine will need a bigger bore zorst so just go for a back box
- FezzR
- God Damn Lazy
stick with backbox for now.
Use Orion 1600 K&N, Part number '56-9042'
Fitting:
Block of the hose that sucks air in (vacuum hose)
Extend the oil filler cap hose and send it to a hole you will drill in the bottom of the K&N, the hole has to be 2mm too small the size of the hose so it will hold it in nice and tight.
Don't just run a breather filter of the filler cap as it will:
leak oil fumes into the engine bay, and you can smell the in the car :|
doing it my way recycles the fumes back into the inlet manfold as it is spose to
any questions, reply or email me
Fitting:
- Liebo
I thought you couldnt get Induction kits for carburetter engines.I was on about the old replacemt filter.
If i could get the orion 16 one would it be any good
Cheers Rum
Cheers Rum
- rumtickler
- Liebo
