How Can I Make it Quicker!
7 posts • Page 1 of 1
I Have a Fiesta MK5 16v 1.25 Zetec (yr 2000) and have just fitted a pipercross induction kit and it has made a great difference however i would welcome any advice or tips on how to make it quicker without damaging anything or doing anything over the top eg NOS.
- Batch
If yo wanna do a top speed test find the biggest cliff you can and then push the car over it
The car will go faster than ever before, just need some TLC though if you wanna drie it much more
Seriously though, wait a while till premiums drop then get a bigger engine in it
Lower than a snakes bollox
- Big Walker
- Your car: Seat Ibiza
something that people dont realise is that new engines are almost always pushed to the limit when it rolls out the showroom in order to try and stop people tuning them and getting themselves killed
on a new 1.25 youd probably get a 5 percent increase with induction kit new filter blah blah blah
on an old 1.3 out of an escort you can easily get another 30 percent but then your stuffed
get an old engine they have a bigger tuning plane for the same capacity(or close enough) and they are a lot simpler too
- edders
lol ha ha! so apart from pushing my motor over a cliff and changing the engine! something a little less drastic- like new cams or other snap on mods or sports chip... cheers- btw do i need to tell my insurance about my new induction kit...
- Batch
If you wanna be covered , then Yep
Prob only add up to £50 more - £150 at the most for the year
- Big Walker
well what my brother did was a k&n filter and a peco catback and the throttle response increase ,top speed increased (not by much) and it sounds phenomanal and that was only a 1.3
how do you mean ott
theres only an induction kit,exhaust,filter that isnt ott the way you said it
i suppose you could try octane boost but thats temporary and wouldnt really be noticable
cams are quite expensive and dont get a second hand one but they are a good way of unlocking potential just not upgrading output
you could try a set of carbs like 40's or 45's but they to are expensive and require a lot of setting up
sports chips are quite a cheap and easy way but effectivley give all your fuelling components a half life as they arent designed to work harder than theyre meant to
if its something temporary like at a thrash you could strip your car out internaly
gearboxes with taller gear ratios can push more speed but not power
not much more to be said
how do you mean ott
- edders
A decent exhaust back box and after that stop. You will have to throw silly cash at the engine to gain anything. The best bang per buck will be Nitrous but insurance companies run away screaming "wibble!" at the slightest mention of the N word.
Your best bet is to add mods that you can transfer over to your next more powerful car in a year or so.
