how can u tell if u have a t3 turbo
7 posts • Page 1 of 1
- AZE_B
It will say T3 on it.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
The T3 is bigger than the T2 and the air filte is typically relocated to sit underneath the battery.
With a T2 the air filter sits on the left hand side at the top of a large S shaped pipe
Can do it in a day if you know what you are doing.
You will need:
ERST T3 and exhaust manifold
T3 rubber oil return pipe
T3 block push fit for return pipe
Oil feed hose
ERST downpipe
Assortment of boost hoses
Mate with a welder
Don't forget to move the rad forward or you'll put a hole in it.
And don't forget to prime the turbo upon fitting
You will need:
Oil feed hose
ERST downpipe
Mate with a welder
