How do I fit a cossie fuel pump?
9 posts • Page 1 of 1
Now we'll say for arguments that my car is a FRST as everything that's relevant is the same.
I have a Grp'N cossie fuel pump which i'm going to have another go at fitting inside my tank (I don't think I fitted it right the first time).
Now it's about 2 or 3 times the size of the original in-tank fuel pump so I won't be able to simply fit it in place of the old one.
My question is.....How to you sit it in the tank (or swirl pot) so that it is able to suck fuel all the time, as it's laid on its side at the mo and can't suck the fuel in when i'm going round bends
- muffking
the way i fitted mine mate was to drop the tank, take the old one out, and simply put the new pup in the place of the other one and put it back in the tank!
- xrsi
- XR(ustyAtTheMo)SI
i think muffking is using the cossie bosch one that the whole bottom of the pump is the suction for it and it will not fit the craddle of the stander pump.
you are surposed to buy with it the fitting kit which has instructions and some straps so that it can be fitted (not very well).
its a case of trial and error untiil its right i think.
thanks
oriont
thanks
oriont
- oriont
you have to align the pump so that it only just fits through the top hole and rests just off the bottom of the swirl pot
it takes a bit of time to get it just right
instead of spending loadsa money on the fitting kit all you need is a couple of jubilee clips and a length of fuel hose
- nigel
Good guess mate it's the Bosch one, I should have said that to start with
What I have done so far is to fir a rubber hose around it so it doesn't start knocking around in the tank, and i've laid it on its side at the bottom of the swirl pot. I've then used a fuel hose to joint it to the metal fuel line at the top of the tank.
My main 2 problems are that when fuel goes dows to 2 third of a tank, the damn thing starves of fuel, so surely I can't have mounted it corectly. The other problem is that there was no room for the float on the sender unit, so I now have no fual guage, meaning I have to keep filling up because I don't know how much fuel i've got.
Is it possible to get a more powerfull pump which is similar in size to the original pump like XRSi suggests. If there is then I may aswell fit one of those and save myself some problems.
- muffking
it was easy!!!
mine fitted into the origional pump housing thingamy whatsit!!
however i fitted it through the bottom of the old housing as it holds it all in place of the origional one taht way so should work the same!
- xrsi
- XR(ustyAtTheMo)SI
The problem is that mine's twice the size and won't sit vertically in the tank 'cos it's to tall. Where did you get yours and what did it cost?
- muffking
matt (ml developments) i got mine from!
is a lucas one and fits in perfectly!
cost somewhere round £80 i think it was, cant remember tho as i brought loads from him that day! lol
- xrsi
- XR(ustyAtTheMo)SI
