how easy to fit new springs?
8 posts • Page 1 of 1
hello there, im just wondering how easy it would be to fit new spings to my car to lower it around 40mm?
can it be done at home or does it need a pro?
thanks chris
thanks chris
this is my fez standard above, passed in aug, best thing i have every done.1.25 zetec s.
- festafoff
Re: how easy to fit new springs?
Can be done at home if you have right tools, most people would have all the things you need with the exception of spring compressors. You need these to compress the spring to you can take the strut apart, if you dont have them and you undo the strut they fly apart this can be very dangerous. Not a very expensive tool but a must for the job.
- JamieFRST
- Keep It Tidy
about 20 notes ish for a pair, they're the sort of thing that if you buy them even using them once you will save money and always handy to have even if they only do get used once every couple of years. but as with all safety related jobs, if you are not sure get a pro (at least someone who's handy with cars) to do it, give you a hand, or at least check it over after
- marty-the-tool
thanks i think i will be giving it a go.
- festafoff
Can be done at home if you are competent and have a good set of spring compresors. My brother and I haven't managed to beat our 45mins start to finish yet but we've got a car we are about to have a crack on in a weeks time
is that a side each? i always get 1 siezed bolt dammit! always wire brush and copper slip everything when i put it back together these days, just to make it easier if it has to come apart again!
- marty-the-tool
Pretty much although there is often a little mucking about to be done. The rears are loads easier to do, most of the time goes on the fronts
marty-the-tool :is that a side each? i always get 1 siezed bolt dammit! always wire brush and copper slip everything when i put it back together these days, just to make it easier if it has to come apart again!
Mines at a garage as the bolt got stuck then the head sheared off
charming
- Andyfloss03
