How low can i go?
13 posts • Page 1 of 1
How low can i go?
I'm looking for 15"ers on 45 prof tyres
I wanna kno jus how low can i go on coilovers with archwork done
Also whats the best coilover 2 get and how much does archwork cost, i kno you can do it yourself but i cant
Cheers, matt
Cheers, matt
- Matt L
I have a -60mm drop and my 15's with 45 profile tyres rub! So get your arches done
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Fezzy Turbo :I have a -60mm drop and my 15's with 45 profile tyres rub! So get your arches done
I've already got that
I want lower
What im looking for is lowering in the region of 60-80mm or 80-100mm
Want the wheels to disapear in2 the arches
- Matt L
Your going to have problems with your lower arms if your going that low. I have to change mine once a year as it is.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- lazy_arse_pie
Surely with those kind of massive drops the damping stroke is gonna be so short even with shortened dampers that its gonna ride like a pig, and be bouncing all over the place on the road?
Thats not to say that it doesn't look cool as a show car though
- Snyx
Snyx :Surely with those kind of massive drops the damping stroke is gonna be so short even with shortened dampers that its gonna ride like a pig, and be bouncing all over the place on the road?
Yea i've been told about that mate but when doin this stuff praticality has never been an issue of mine
Gonna have to wait until after the MOT just in case it fails though
- Matt L
- Xr_Dub
Mines a base model buts been dropped using an 80mm kit for an RS1800 so is seriously low, have no problems what so ever with rubbing or had to do any arch work but I running 185/55/14s on 6x14 alloys which are slightly larger in diameter than 195/45/15s but don't have the extra width. Well tell a lie needed to fit an RS Steering Limiter kit as the tyre sidewall was rubbing on the front in arch at full lock, but this would have been a problem with standard suspension for me anyway.
The biggest problem is the centre section of the exhaust dragging along the ground and speedbumps. Lower arms and driveshafts now point 45 degrees upwards (which isn't ideal) and there is a serious negative camber and the tracking takes a while to set up. But handling is spot on and I could go lower still.
Check out the negative camber.....
- tompeteRS
- Authorised Trader
Not at all as i havent used poly bushes on my suspension, only the ARB's. Okay i get some tramlining, but it handles well
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
