How much boost?
12 posts • Page 1 of 1
How much boost?
I had my FRST chipped yesterday with the OFAC 165 superchip. I have an uprated T2 -75 actuator and it's only running 12psi. This is with the actuator arm wound right in...?
Is this all the boost i can run?
It's on its original T2, with pace intercooler, re-built 30k ago, kent cam, lightened fly wheel.
- LeeM2
LeeM2 ......
whats a -75 actuator ???
and a Pace cooler is no better than a std Ford cooler
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
you might as well buy some matches and go to the cash machine, take out £100 quid and set fire to it, cos ull soon be rebuilding the engine again
a bleed valve will just turn up the boost with no accuracy, it will also not cure your cooling problem that the Pace will be causing, it wont adjust a fueling so you will be running lean
if you want results your gonna have to be prepared to pay for them
- FezzR
- God Damn Lazy
The uprated actuator for a T2 is a -32 and its the only uprated actuator i know of for the T2.
As for using a bleedvalve, well i have been using one for nearly 50k miles. There is NOTHING wrong with a lockable bleedvalve as long as you LEAVE IT ALONE and you have a good boost gauge to keep an eye on your boost, but everyone i know fits a boost gauge anyway.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
