How Much Electric Do I Need
6 posts • Page 1 of 1
Hello,
My Wife's little car is: Fiesta MK3, 1300cc, HCS, CFI, Manufactured Nov 93, Reg Jan 94, 3 Door Hatch.
I'm adding the loom and fuse box from a RST 1800. Then Electric: Windows, Heated Window Screen, Central Locking, alarm, Twin Head Lamps, XR2i Fogs and driving lights, interior lighting from higher specification car.
Question-1, Will I (can I) Fit a higher rated Alternator/Battery? To deal with all the extra power consumption when driving at night or in inclement weather condition.
Question-2, Altering suspension, adding rear beam off a RST 1800, and 15" Alloys with 195x45x15 tyres, will I need to have the:
a) Clocks: speedometer and Rev-counter re-calibrated,
b) Camber angles altered?
Any other checks or alterations required ?
G)
G)
- grandman
Re: How Much Electric Do I Need
alternator you could fit a td alternator to get more spark but you dont need to
15" wheels wont need the speedo reclaibrating as the rolling radius is the same
if you fit a rear beam you could do with getting the tracking checked at the local garage but dont have to
- HCS PIMP
and if u want to fit a higher amp battery you can do as long as it fits on the battery self id go for a 480 just to be sure ull never need to jump start it alternators and batteries aren't cheap unless u work at halfords liek me so i say ull be fine my 1.1 ran full electrics and a chive bass syhstem with 12 speakers in total with no need for a new battery or alt
- HCS PIMP
HCS PIMP :alternator you could fit a td alternator to get more spark but you dont need to
Hello,
When you say a TD, is that a turbo diesel? If so is that the 50amp or 75amp, with bolt on connections? Do I also need to alter anything else. like plugs or anything if the spark is going to increase. What is a 480 battery is that the charge rate or something else?
Thanks in advance for your help.
G)
- grandman
Don't bother changing the alternator until it buggered as it will be able to cope. Uprate the battery if you like but personally I'd wait until the one have is buggered, I think the usual one to go for is the Transit diesel battery.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Ollybee :I think the usual one to go for is the Transit diesel battery.
are you sure? theres one on the floor in my dads van and its fecking huge.i wouldnt have thought it would fit properly on the battery tray.
- edders
