how much should these cost???
8 posts • Page 1 of 1
Hello all am doing a T3 conversion at the moment and rang up Ford the following parts and got quoted the following
Escort RS Turbo oil return drain pipe (metal pipe with flanged fitting) £48!
Escort RS Turbo oil return elbow pipe (rubber pipe with slight bend) (FINIS: 1640090 £9.95+vat) £36!
I see it says it should cost 9.95? where is this from?
is this the normal rate or am i being stitched up?
- rsmcelroy
Simple solution .................. Don't go to FORD.
Goto a hydraulic place they should be able to sort you out with, fittings, braded hoses the lot at a fraction of the price that Ford will.
- Low Down And Dirty
- Location: Andover ish Drives: RS1800 and Overfinched Range Rover
- krsi
