How the FCUK do u fibreglass?????
Postby festajon on Wed Jan 30, 2002 1:13 am
Right i got some skirts and arches for an xr2i for me 5 door :lol: and have trimmed the rear arches so they get past the door (as opposed to cuttin a huge chunk out and stickin it to the rear door)
Where the rear of the skirt curves up to meet the rear arch it comes across a small section of the lower rear doors so i removed as little as possible of this to allow the rear doors to open and now there is a small gap about 1 inch by 2 inches that i need to fill with fibreglass. Only problem is i don't have a fappin clue how to do this!!!!!!
I've seen the little kits in halfords and believe this would work but i dunno what i'm doing as i never done this before. What do i have to do!!!!
Jon
Oh and the skirts and arches are fibreglass too if that helps!!!
festajon
Postby Danny 2i on Wed Jan 30, 2002 2:31 am
Fibreglass in a tub is a right bastid to do properly so i think u r best of mixing it with some filler. Spread it on as smoothly as u can and mask off the area around where u will be filling (cos it makes it much easier to sand afterwards).. When u apply the filler/fibreglass mix get a blob on the end of your spredder and press it flat down firmly against the area u wish to 'glass.....use different grades of wet 'n' dry paper to sand it off
Danny 2i
The White 2i Guy!
The White 2i Guy!
Your car: N/A
Postby Mike on Thu Jan 31, 2002 7:21 pm
Make sure that you wear a pair of rubber gloves as well, otherwise you will be spending the next two weeks trying to get the crap of your hands!!
Mike
Postby 2iMadman on Fri Feb 15, 2002 12:20 am
Ideally use P40 which is bridging filler to plug the gap with a dip for P38 the finishing filler to tidy the job.
Wear gloves and be careful how you mix the quantities.
A golf ball of the main stuff to a pea of the hardener is about right.
2iMadman
Postby scraft on Sat Feb 16, 2002 12:25 am
go to hlfords and you can buy "davids" fibre glass kit, its got everyhting ouy need, its so eay to use aswell! i've joined my st24 skirts with it! its proper good!
scraft
