how to fit escort bailey breather
13 posts • Page 1 of 1
i have an escort rst bailey breather which i want to fit to my fiesta rst, the fiesta has a strut brace fitted so i'm not sure where i should mount it and what hoses i would need and idears anyone?
- tat2cliff
- Your car: ford fiesta rs turbo
- FRSJON
- tat2cliff
Re: how to fit escort bailey breather
its bolted to the far right stud that holds the two halves of the inlet together.. you need to heat the fixing tab on the breather and twist it 90 degrees..jano's done loads of them
- FRSJON
FRSJON :its bolted to the far right stud that holds the two halves of the inlet together.. you need to heat the fixing tab on the breather and twist it 90 degrees..jano's done loads of them
i brought a secondhand breather and the bracket has already been bent so i just need to measure the diameter of the hoses i require and order them and it looks quite straight forward, do you have any idear where i might get a coolant temp sensor from?
- tat2cliff
tat2cliff :FRSJON :its bolted to the far right stud that holds the two halves of the inlet together.. you need to heat the fixing tab on the breather and twist it 90 degrees..jano's done loads of them
is you sensor definitely playing up? i have a couple
- FRSJON
FRSJON :tat2cliff :FRSJON :its bolted to the far right stud that holds the two halves of the inlet together.. you need to heat the fixing tab on the breather and twist it 90 degrees..jano's done loads of them
not a hundred percent sure mate as it needs a set up but last time i was over janos he said some of the probs the car was having could be down to this however this was prior to the new ecu i just thought if i had a spare one when i go to janos to set it up later this month if there is a problem with it i will have a spare one which could save another trip all the way over there
- tat2cliff
if i still have your address ill get one in the post
- FRSJON
FRSJON :if i still have your address ill get one in the post
how much do you want for it mate have you got paypal?
- tat2cliff
tat2cliff :FRSJON :if i still have your address ill get one in the post
jon how much mate
- tat2cliff
tat2cliff :tat2cliff :FRSJON :if i still have your address ill get one in the post
jon how much mate
dont worry about it mate
- FRSJON
no mate i know these are getting hard to find now, i was told i would be lucky to get one not only that you dont really know me from adam mate so why should'nt you get something out of it?
- tat2cliff
tat2cliff :no mate i know these are getting hard to find now, i was told i would be lucky to get one not only that you dont really know me from adam mate so why should'nt you get something out of it?
ok mate up to you..pm me your address and i cant seem to find it .. paypals jonwilliams76@hotmail.co.uk
- FRSJON
