how to mount correctly boost controller
Postby mbaciccio on Thu Feb 07, 2013 8:49 pm
http://www.ebay.it/itm/BLACK-MANUAL-BOO ... 1e770f5b52
how to correctly Mount it?
I've got cuts when turning for more pressure!!! mine is an ofac (new ecu, old ofab) and without using the overboost sensor, or leaving it without hoses, it cuts when pressure increase...
somebody helps me?
mbaciccio
Re: how to mount correctly boost controller
Postby Dave5300 on Sat Feb 09, 2013 8:24 pm
what pressure are you trying to boost mate? without a chip the ecu will cut fueling if the boost is raised to much above standard
Dave5300
Postby mbaciccio on Mon Feb 11, 2013 4:53 pm
the problem is that... so if I'll Mount a superchips 195 bhp with manual boost controller and beige injectors (i've already got a frontmount intercooler) it will not give me problems?
but do you know how to Mount it? the overboost sensor still not have anymore hoses in? I've got also k&n air filter with no box...
mbaciccio
Postby rich1987 on Mon Feb 11, 2013 6:46 pm
Ive got beiges and 195 chip on ofac with manual boost controler and ive ran about bar and a half not problem, not for long tho then turned it down, be careful tho as a mate of mine did the same but a pipe came off the contoler and his turbo ran massive boost and nackered his engine and turbo
rich1987
Your car: fiesta rs turbo (zvh)
Postby Dave5300 on Mon Feb 11, 2013 8:00 pm
on my current setup i have a 165 chip and can adjust the actuator to run 12psi without hitting fuel cut no problem, what boost are you looking to run?
Dave5300
Postby mbaciccio on Tue Feb 12, 2013 1:19 pm
I'm looking for 0,8-1 bar but the problem now is that without chip it cuts also at 0,5! I've got a electric boost gauge and when the manual boost controller is closed, it cuts however.
anyone could tell me the instructions to install properly the manual boost controller?
mine is installed with an hose from actuator than a T piece that goes one to compressor housing and one to manual boost controller and the second tube of the controller is free... no hoses to the overboost sensor... is it right?
mbaciccio
Postby rich1987 on Tue Feb 12, 2013 1:41 pm
It should be from the compressure housing into the boost controler out the othereside of the boost controler into the actuator
rich1987
Postby mbaciccio on Tue Feb 12, 2013 3:54 pm
ok, it's mounted right... the only difference is that the controller is on board and there I've got a T piece...
mbaciccio
Postby rich1987 on Tue Feb 12, 2013 6:56 pm
Why have you got a t-piece? Where does the pipes go from the t-piece?
rich1987
Postby Dave5300 on Tue Feb 12, 2013 7:08 pm
Theres a t piece for the feed to the amal valve. Personally i wouldnt use a bleed valve to wind up the boost, id adjust the threaded rod on the actuator, along with a chip of coarse to prevent fuel cut
Dave5300
Postby mbaciccio on Tue Feb 12, 2013 7:12 pm
rich1987 :Why have you got a t-piece? Where does the pipes go from the t-piece?
one to compressor housing the second to the amal valve...
I've got a t2 with standard actuator... and I haven't already mounted the chip cause I'm waiting for beige injectors to arrive.
ps
I've done the head work the last month but now when the temperature rise and the fan work, turning off the car, I heard bubbles sound from the thermostat housing and opening the water tank cover I could hear the same sound and a lot of heat air.... somebody knows?
mbaciccio
Postby rsturbonutter on Tue Feb 12, 2013 8:12 pm
The bubbles etc could just be an air lock. As said above manual boost controllers are dangerous. Get a chip get beiges and either a uprated actuator or actuator wound in personally I would get a uprated one and then get a set up. Winding the boost up without adequate fueling is not good because your mixture is incorrect even if it is just for traffic light grand prix's
rsturbonutter
Your car: Fiesta RS turbo
Postby mbaciccio on Wed Feb 13, 2013 11:25 am
rsturbonutter :The bubbles etc could just be an air lock. As said above manual boost controllers are dangerous. Get a chip get beiges and either a uprated actuator or actuator wound in personally I would get a uprated one and then get a set up. Winding the boost up without adequate fueling is not good because your mixture is incorrect even if it is just for traffic light grand prix's
hihihi, not so bad... hhihi
ok, I've mounted a egt and a stechio gauges... so I could control the air/fuel ratio and also the working conditions of engine.
but ok, I'm waiting for the beige, then I'll replace the blue ones and try to make my best air/fuel ratio with a bar boost pressure with 195 bhp superchips chip.
ps
the air lock how could be erased?
mbaciccio
Postby mbaciccio on Wed Feb 13, 2013 12:00 pm
is it possible to Mount front and rear brakes of a focus 1.8 tddi my 2001?
mbaciccio
Postby georgiocat on Wed Feb 13, 2013 1:00 pm
Well to remove the airbubbles let the engine work till the radiator fans start working,and with the heater on inside the car,squeeze the radiator and heater matrix hoses 6-7 times.If there are air bubbles they will go to the highest point of the thermostat housing,the small top hose of the housing that goes back to the expansion tank.This small hose is the overflow hose and also is used for bleeding the coolant system.Something I read very often is to let the engine run with the expansion tank cup off.This is not right.From what we know from physics,the water boils on 100C at atmospheric pressure.Since engines get hot,the water gets hot,and when it boils pockets of air are created and topically the temperature gets really high creating fatigue to the metals and especially on joints that have gaskets.This is the reason that the cooling system is sealed,it is pressurized,and in that way we raise the boiling point of water...
Regarding the air-fuel gauge,I guess you bought a wide band gauge...only them are accurate on their readings.
My Ford Escort ride
georgiocat
Postby mbaciccio on Wed Feb 13, 2013 5:15 pm
georgiocat :Well to remove the airbubbles let the engine work till the radiator fans start working,and with the heater on inside the car,squeeze the radiator and heater matrix hoses 6-7 times.If there are air bubbles they will go to the highest point of the thermostat housing,the small top hose of the housing that goes back to the expansion tank.This small hose is the overflow hose and also is used for bleeding the coolant system.Something I read very often is to let the engine run with the expansion tank cup off.This is not right.From what we know from physics,the water boils on 100C at atmospheric pressure.Since engines get hot,the water gets hot,and when it boils pockets of air are created and topically the temperature gets really high creating fatigue to the metals and especially on joints that have gaskets.This is the reason that the cooling system is sealed,it is pressurized,and in that way we raise the boiling point of water...
thanks to you and to everybody helping me...
I want to know also if I could Mount the entire brake system from a focus model year 2000
mbaciccio
Postby mbaciccio on Wed Feb 27, 2013 2:04 pm
ok, new beige injectors mounted, ofac 195 bhp superchips mounted but it runs bad...
at minimum range smoke and seems like working a 3/2 cylinder.... when reving up it seems to work better... but when it goes back to minimum range it run off....
somebody knows or does anybody got a superchips 195 bhp ofac that could give me the serial number written on it?
mbaciccio
Postby rich1987 on Wed Feb 27, 2013 5:04 pm
Can have a look on sunday mate if no one does before hand
rich1987
Postby mbaciccio on Wed Feb 27, 2013 7:08 pm
many thanks...so you got a 195 bhp ofac superchips? do you got the same problems as mine?
mbaciccio
Postby rich1987 on Wed Feb 27, 2013 7:57 pm
Yeah ive running ofac with a 195 chip but never had a problem to be honest fitted the injecters pluged the chip in and away i went
rich1987
Postby ~S1~ on Wed Feb 27, 2013 8:47 pm
When you swapped from 0FAB to 0FAC did you also swap to the correct MAP sensor?
~S1~
Hold On...
Hold On...
Postby mbaciccio on Wed Feb 27, 2013 9:42 pm
I've to ask to my friend that made all works.. otherwise, there is a code I can find out the difference? and the map sensor is the one located behind the inlet manifold looking to the right?
mbaciccio
