Hows the rev limit on EFI raised (FRST management, OFAB)
4 posts • Page 1 of 1
as above really
On the RST MFI, you need to change some bits in the fuel ECU, well FRST management doesn't have one so anyone know how its done ?
Anyone who's actually had it done ?
Adam
- blackRS
From what ive heard some chips will do it but u need solid lifters (don't actually know what they are, lol) and a balanced bottom end.
- MIK3Y
surely it will be in the map?
above such and such a revs equals no igntition, above such and such more revs no igintion or fuel? or something along those lines?
thats how i thought it worked but im not 100% on it
MELV
Still needs a new sig!!
1.6CVH EFI mk2 turbo (not running needs new front panel)
1.8 16v Focus Turbo! (Leaking oil and doing 1300 miles a week!)
and Honda CBR600 (loving the revlimiter)
- M Brian
exactly, stu will have set it in the chip.
Mik3y - that has nothing to do with it. if you are revving to certain rpm you may need to change the lifters, anti-pump should be fine to 7200 before you get valve bounce, after that you would need to get solid lifters and a cam that can suitably use solid lifters, but the rev limit is in the chip.
I'm currently running in and I have a 5k rev limit and 6.5psi boost limit, it just cuts everything out after that.
BSW 07747 811981
Engine Advantages 01376 502522
Norris Motorsport http://www.norrismotorsport.co.uk
288.2bhp / 265.8lb/ft @20psi
- Jon ERST S2
