hyrallic to solid lifters
4 posts • Page 1 of 1
I've got a s1 2.0l 16v zeta engine that i am in the middle of rebuilding
after reading performance ford this month it says that solid lifters can handle more bhp than the hydraillic lifters
in the zeta engines
ive been given a s3 zetec head before i buy this head: -
1.is performance ford mag right about hndling more power
2.Would i be able to do a straight swop from hydrallic to solid
3.will the head from the s3 zetec fit on the block from the s1 zeta
in the zeta engines
RS1800 Done and dusted
- Dwayneology
- Your car: Yamaha YZF R1, RS1800
Re: hyrallic to solid lifters
not sure on the first 2 but as far as i'm aware the 3rd is a straight no lol.
- Tweek
- Your car: VW Golf GTD
The S1/2 Zetec's have bigger main bearing caps so there a little more stronger than the S3
Performance ford didn't tell you everything about this mod
All black top zetecs run solid lifter, you would really see any gains in fitting these unless you go for really wild cams then you need to fit solid lifters but of the over size type as the wild cams need more area of the tappet face to stay in contact with so you have to machine the head to fit 32mm tappets
If you do this you can fit Vauxhaul EX Red top tappets, there hydraulic but can handle more power than the Zetec ones, there of for 220bhp then you will need solid ones
The head from the S3 will fit the S1 block but a modified water pump housing is needed as well as a electrical water pump as the S3 timing belt will foul the S1 water pump
- freak power
solid lifters will handle more revs then hydraulic.
sean
sean
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
- turboboss
