ICE in a mk6 Fiesta?
7 posts • Page 1 of 1
Hi!
This coming weekend Im fitting an ICE in a mates fiesta mk6
Had a good look, but cant for the life of me see a good place to route the cabling into the engine bay!
Im sure its been asked before, but I cant find anything, so any advice much appreciated!
Tim
Tim
- phatboy
if you do have to drill a hole which sometimes its the only thing to do without spending hours of pissing about for no reson, make sure its
a, clear at the other side
b, close to some where you can secure the cable to in the engine bay so its not just hanging all the way to the battery
c, rust proof the hole you have drilled with rust remedy etc, then dab some paint round it
d, use a correctly sized grommit in the hole and once the cable is in position and through seal it with some silicon or similar product to seal any gaps
good luck
good luck
- Priezti
there will be a loom hole somewhere , im not sure where though , mine was under the header tank but it will be somewhere around the bulkhead .Ste
- spannerste
- Your car: 89' escort rs
hi!
Well, its all done now!
I found that right up behind the glovebox on the left, there is a large wiring loom that goes thrugh the bulkhead. It is in a big grommet, so it was easy enough to make a small cut in the grommet, and put the extra cable through
- phatboy
