idling high problem
idling high problem
Postby fezzRS on Mon May 06, 2013 10:02 pm
ive got a problem with the idle its ive unplugged the tps and iscv but there doing nothing car still idles high can anyone help i jsut want it confirming if the sensors am at fault
Your car: run about
Re: idling high problem
Postby FRSJON on Tue May 07, 2013 5:32 pm
sounds like a air leak.. check vacuum hoses :)
FRSJON
Postby fezzRS on Wed May 08, 2013 8:06 am
Tried for air leaks mate the idle valve is making a right noise grumbling thinking converting to ofab when i plug the fault code reader in the revs go up it came up with map sensor idle valve
Your car: run about
Postby j7aoc on Tue May 14, 2013 8:08 pm
My friend had a problem like this so we started the car up with out the rocker cover on, I know it sound's bad but we found one of the rockers had ripped out of the head, so he had them re-done as it was a stage 3 head and worth the money to fix, so if it's not an air leak or inlet problem might be cam or head/rocker problem
j7aoc
Postby fezzRS on Wed May 29, 2013 3:53 pm
Took it to have the emossions checked passed mot the xp was high setup the enidsions
Your car: run about
