idling problems
idling problems
Postby Razer on Wed Jul 03, 2013 10:42 am
My engine runs like crap at idle.
when you start the engine it runs at 1500 rpm, also it looks he is misfiring. When that appears the engine will idle to 2000 rpm and it's gone
When revving the engine, the rpm won't drop below 3000 rpm :-?
It's a rs1800 zetec engine, with a ported and polished head, others cams, rover turbo inlet manifold from crazycage and a frst throttlebody, also fitted a 2.0 air mass meter
havn't fitted a idle sensor
It runs on a rs1800 management with a powerchip
FORD = First On Racing Days
Razer
Your car: MK3 RS1800
Re: idling problems
Postby Razer on Wed Jul 03, 2013 6:14 pm
i have fitted the air mass meter internals from a rs1800 instead of the mondeo 2.0
Runs better but not good enough, still idling between 1500 and 2000 rpm.
No diffrence with or without chip
Razer
Re: idling problems
Postby AW0L on Thu Jul 04, 2013 11:53 am
try fitting the idle sensor...
AW0L
Re: idling problems
Postby Razer on Thu Jul 04, 2013 5:49 pm
havn't got place for it on the manifold :(
Razer
Re: idling problems
Postby fezzRS on Thu Jul 04, 2013 6:28 pm
normally its a fuelling problem prob fuel pump fuel pressure injecotrs blocked pipes blocked dodgy fuel faulty pressure regulator the list goes on try some redex in it mate
Your car: run about
Re: idling problems
Postby Razer on Thu Jul 04, 2013 11:11 pm
Hmm interesting, the fuel pump is an new uprated cosworth one.
I will try to fit another fuel pressure regulator. This one is a rover turbo one, maybe it's faulty.
Razer
Re: idling problems
Postby AW0L on Fri Jul 05, 2013 12:25 pm
Razer :havn't got place for it on the manifold :(
fit one remotely, one port to a pot on the inlet and other stick a breather filter to, i have had to do this with my gsxr1000 throttle bodies to run megasquirt
you can just about see the filter under the TB's
AW0L
Re: idling problems
Postby fezzRS on Fri Jul 05, 2013 2:19 pm
make sure there is a o ring on the tps because that can cause issues
Your car: run about
Re: idling problems
Postby Razer on Tue Jul 09, 2013 2:57 pm
looks nice, with kind of tps did you use ?
Razer
Re: idling problems
Postby AW0L on Wed Jul 10, 2013 12:11 pm
Razer :looks nice, with kind of tps did you use ?
thats using the gsxr1000 TPS...
AW0L
