ignition cuts out randomly
Postby Razer on Sun Aug 23, 2015 4:58 pm
I have a zetec 1.8 16v silvertop with an kfdi management
It did run good until a couple off weeks ago
it randomly cuts out the ignition ( coilpack ) and won't start ( it does crank ) untill you release the connector from the coilpack for about 30 sec.
tried another coilpack, and checked the wiring, but stil no result
Who knows this problem or has an idea what it could be
FORD = First On Racing Days
Razer
Your car: MK3 RS1800
Re: ignition cuts out randomly
Postby snake on Wed Aug 26, 2015 11:42 pm
try the crank sensor, also double check the pins in connectors (coilpack too) as they can corrode or splay (spread) over time
snake
Trainee Burger Flipper
Your car: ford
Postby chrisxr2it3 on Sat Aug 29, 2015 10:28 pm
Have you checked your alarm? I had an alarm on mine once that got a bit temperamental,the immobiliser would randomly cut in while driving which would just shut car off without warning
chrisxr2it3
Postby Razer on Mon Aug 31, 2015 9:35 pm
Changed the coilpack, cranksensor etc
The problem is that the 12volts is gone for a while and 10 minutes later it's back
Everything elso works, so injectors, fuel pump
havnt got an alarm , so that won't be the problem
Razer
Postby Razer on Mon Sep 14, 2015 8:43 pm
Found the problem.
The drivers for the ignition coils are not good.
Send it back to the manufactuer and did get a new one
Razer
