IM NEW NEED HELP WITH MY FIESTA 2 LITRE ZETEC
Postby jme on Tue Jan 20, 2009 5:47 pm
HI I HAVE A FIESTA MK3.5 WITH A 2 LITRE ZETEC IN IT.WHAT ARE THE BEST DRIVE SHAFTS TO FIT TO IT AS I STILL HAVE THE 1.6 IN THERE,WHAT IS THE BEST FUEL PUMP TO FIT AS I STILL GO THE 1.6 IN IT AND WHAT BRAKES CAN I GET TO FIT STRAIGHT ON THAT WILL HAVE A BETTER STOPPING TIME?
PLEASE GIVE ME SOME HELP REALLY WANT TO MAKE THE MOST OUT OF MY FIESTA
jme
Re: IM NEW NEED HELP WITH MY FIESTA 2 LITRE ZETEC
Postby fiend on Thu Jan 22, 2009 3:41 am
The 1.6 drive shafts and fuel pump should be fine, as far as I know.
ST150 brakes are a straight swap and fit under 15"s.
fiend
Postby frostie on Fri Jan 23, 2009 5:02 pm
as above the driveshfts are fine and been proven to 400bhp +
the fuel pump is good for nearly 180bhp but if you need to no a upgrade well a escort cosworth one will fit in no problems.
the brakes as above again mk6 fiesta st fit no problems or you can fit escort cosworth brakes and discs or mondeo v6 brakes or st170 brakes all fit
frostie
Postby jme on Sat Jan 24, 2009 1:14 pm
cheers lads ill look for the modeo brakes then also ive tried to fit the 2 litre injectors and 2 litre ecu yesterday and it would not start with the 2 litre ecu so put the 1.6 back in and once i put the injectors in it ran like a bag of sh*t,it would not rev above 4k and the brakes failed :S i think ive nakerd it,the brakes only work if you rev it high first then quickly use them,my mechanic checked the vacuum pipes and we fitted the 1.6 injectors back in but still it wont idle,brakes keep failing and runs like a bag of sh*t......PLEASE HELP ME :(
jme
Postby dangerousdave on Sat Jan 24, 2009 2:41 pm
you need the desk or dewy ecu from a 2l mondeo and the 1.6si engine loom!
dangerousdave
Postby Tweek on Wed Jan 28, 2009 12:24 am
Failed servo maybe for the brakes? Without the engine running, push your foot hard on the pedal whilst starting it up, as the engine starts the pedal should sink a little.
I wouldn't even bother trying to run it with the 1.6 injectors or ecu because you won't get anywhere in a month of sundays lol. As above, you need the 2.0 ECU coded either DEEP, DESK or DEWY.
Your car: VW Golf GTD
Postby jme on Wed Jan 28, 2009 11:35 am
it has the 1.6 ecu and 1.6 injectors on it at the moment and it runs pretty good e.g beating golf 1.8 turbo,celica 2l gti ect could i fit the 2 litre injectors straight in?or would i have a problem.what is a deck or dewy ecu ? cant i just stick a ecu out off a mondeo in it?
jme
Postby dangerousdave on Wed Jan 28, 2009 2:04 pm
its the code on the mondeo ecu, it must be desk dewy or deep
dangerousdave
Postby jme on Thu Feb 12, 2009 6:16 pm
oh ok so i got to remap it really,can i just put the 2 litre injectors straight in? what would happend and would it make it much faster?
jme
Postby Tweek on Fri Feb 13, 2009 12:35 am
It'd make it run better and most likely faster yes.
Postby black2 on Sat Feb 21, 2009 9:49 am
While your at it ditch the rubbish si inlet manifold & TB & fit the RS 1800 HO set up on, flows far far better and will really free up the rev range past 4k.
Gareth.
black2
