Imperial blue fiesta rs turbo zetec turbo project
6 posts • Page 1 of 1
I'm just testing the water as I'm bloody skint and need a everyday car (would like a sporty ford) and my house move has near bankrupted me and it's stupid too leave it sitting in the garden
It's a imperial blue fiesta rst that was owned and restored by Chris the painter from the ox- ford group and is in really nice condition apart from a few small scuffs and stone chips
It is unfinished because it needs either a chip or a ofam ecu too finish and a set up, it's a running nearly finished project and I can have it all done ready for chip and injector swap ready to rock and roll
ENGINE:
2.1 silvertop zetec turbo
Lightened and balanced
Shot peened rods
Arps
C20let pocketed pistons
Decked block, skimmed and pressure tested head
Devil developments valve springs
Focus rs gaskets with multi layer head gasket
Zetec inlet modified for custom fuel rail and fuel reg for top feed injectors
Vxr injectors
Modified frst charge pipe to fit zetec
Rouse Motorsport hybrid hose coolant hose kit for perfect fit
Airtec stage 2 rad mounted right in front panel too clear turbo
Grs front mount intercooler
Breather kit
Cosworth 4x4 t3 in perfect condition
Head modified for cvh ex mani, ( properly welded and skimmed for perfect surface)
3" downpipe with lamba with 3"- 2.5" reducers
Up rated fuel pump
Vibratechnics g/box mounts
Single big spal fan
Transmission
Bc box ( lol)
Uprated pedal mod (adjustable clutch)
Up rated g/box mounts
Pretty good gear linkage
Suspension/brakes
New'ish gmax 3.5 fiesta kit
Mk3.5 long studded hubs+ spacers
Rear axle widening kit (on way today)
Rose jointed lower arms (solid bushed)
OMP front strut brace
Cosworth 4x4 calipers
Tarox drilled and grooved discs
Ebc green stuff pads
Custom brackets/spacers not stupid washers stuck together
Braided brake lines
16" white team dynamics pro race 1.2s with nearly new matching tyres
This project has quite a few spares and bits too do but as I said I can get it ready if a deposit is left or take it now with a car full of spares
Bad bits
Needs a chip and injectors to suit spec (but runs)
Needs abit of finishing /detailing
Very dirty as been sat about for 3 months (but I will get the sponge out lol)
Wheels are not mint but are presentable
Rocker cover could do with painting
Exhaust could do with playing around with to get perfect fit
And maybe a few others, I'm stressed out my mind trying to do the right thing but my 2nd daughter is due in 10 weeks are as previously stated I just got a brand new house and there has been so many expenses that I didn't realise I had too spend.
Looking for a quick sale otherwise I will break, there's most likely loads of parts I forgot about, I worked out it would break for over 3.5k so want £2.5k cash for every ford part I own and the whole project
Or will px swap for something nice
A couple of pics coming
07825348906
ENGINE:
Shot peened rods
Arps
Vxr injectors
Breather kit
Up rated fuel pump
Single big spal fan
Transmission
Bc box ( lol)
Suspension/brakes
Braided brake lines
Bad bits
07825348906
- Rsmark86
- Your car: Fiesta rst zetec turbo
Re: Imperial blue fiesta rs turbo zetec turbo project
Also just had
New steering knuckle
Drop links
Polybushes front arb
Frs multilayer h/g kit
Timing belt kit
Water pump
Devils springs
All with zero miles
Pics here
http://m.passionford.com/forum/showthre ... ost6345937
Drop links
Timing belt kit
Water pump
Devils springs
All with zero miles
Pics here
- Rsmark86
Would consider a swap px for another rst that I can just use as a daily for now
But really want a rs2000/ st200/ st220 or st170 or try me???
As said I'm on the verge with breaking it as it's easily worth a grand more, would just need a buyer for the rolling shell first
- Rsmark86
Please remove I'm keeping it
- Rsmark86
