IMPORTANT!! FAO INTELLEGENT PPL ONLY!!!!!
5 posts • Page 1 of 1
right, i need help peeps, got all me bits back from chromers and nothing is fitting where it should, was the late (K plate) FRST accelerator cable bracket a different to the early type cos in haynes it looks nothing like mine. theres also a double threaded bolt which is supposed to fit on the inlet which i dont know where to fit. Also when u take throttle housing off with the 4 bolts, is there a small semi circular plate that fits in there? i remember takin it off but how the hell does it go on??? If u peeps can post some detailed pics of your on here Id much appriciate it thanks.
- KEVFRST
eep oops matey!
For the double threaded bolt, I think that goes in the top right of the throttle body as you look at it from the front slam panel. Then the throttle bracket goes over it and the 10mm nut holds it onto the bolt.
Take yer time and try mate The throttle bodies should all be capable of running both types of throttle bracket so no worries there.
- Project
- fiftyoneCL
