in car boost control
7 posts • Page 1 of 1
in my frst i have a mechanical boost control.
its basacally a knob which u turn anti clockwise to up the psi.
however i dont like it. wud i be right in thinkin that it will only up the boost and wont allow for any xtra fuel so will b more likely to blow the engine?
is it a bleed valve
is it a bleed valve
- Mikee_RS
Car: 1995 Ford Fiesta
it won`t allow for extra fuel past the ecu`s limits, so 165 chip, they say 14psi i think so thats the max it is fueled for, standard it will cope with 9 psi, 10 at absolute max as i know some standard ecu`s allow this boost without cutting out. turn the controller past this and u risk dettin, obviously have to consider inlet temps aswell
- snake
- Trainee Burger Flipper
- Your car: ford
yeah i thought it was a bit dodgy! been drivin the car 4 a while now and always resisted the temptation to turn it up. think ill get it removed.
say i gotthe car chipped and set up propely, wot do u think about the electrical switch boost control. low boost then swich up 2 high. if its set up to allow 4 extra fuelin then everything [ERRR] b ok yeah?
- Mikee_RS
been posted b4, u set the boost to max that u will run and get the ecu mapped to this, the ecu will adjust itself for lower settings, but it will not have values in the ecu if u have it mapped at 14psi, then run 16psi, the ecu will not have values in it for 16psi, so u will underfuel, so u need it mapped for high boost settin on the switch
- snake
- Your car: ford
If u get ur chip set-up to run 10psi then it won't underfuel at 12psi will it cause it will adjust fueling for u won't it?
Is this different in the case of a Superchip & a Motorsport Development chip which u hav set-up?
Thanx
Thanx
- MIK3Y
