In-car boost valve
6 posts • Page 1 of 1
In-car boost valve
I've seen this on Auto Specialists' website. Is it any good for a FRST???
https://secure.encryptedspace.com/autospecialists/cart.php?m=product_detail&p=322
Appreciate your advice!
Nelly
Nelly
- NellyFRST
Will work, as its basically an in car bleed valve that is used on tuning turbo cars.
The problem is you WILL want it running max boost all the time, that will mean if you have your car setup to run like that and do actually turn down the boost, you will over fuel. If its setup the other way, you WILL blow up your turbo or engine. I have seen them used on a few turbo cars and they usually end up the same ....... in the bucket.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
I've got a two-stage boost switch in mine, which allows me to use about 12psi and 16psi depending on what position the switch is in. It's been set up to run properly on either stage of boost. Contact Motorsport Developments if you want one like that. I believe Grove Garage can do them too.
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
