IN NEED OF HELP FOR MRK 5
Postby Rob07 on Wed Feb 03, 2010 2:48 pm
Please help i have a mark 5 fiesta which looks like
i need to do some basic mods just to make it look that much better, i need some help.
how can i remove the badge at the back and still have my back look smooth, how will i get rid of were the key goes?
where can i get smoked rear lights?
how do i debadge the front? and detango my front lights? and if anyone knows any others i can do. Please suggest some :)
Rob07
Re: IN NEED OF HELP FOR MRK 5
Postby sikora on Mon Feb 08, 2010 11:20 pm
Do you have a remote boot release? I had my boot smoothed on my Zetec S. Needs to be welded tbh. Filler will be no good.
Front grill can be replaced with a phase 1 zetec s grill. mainly W and X reg. its steel mesh and the badge come off. You may be able to swap the surround too. later zetec s grills are plastic like yours is.
To detango your lights you need to remove the metal clips from around the glass and heat the glue up holding the glass to the headlight with a hairdryer. use a screwdriver to carefully pull them apart. the orange tint is just clipped in. Reheat the glue up to join back together. may need a bit of silicone sealant over the seam to make them watertight.
As for other things, you should be able to pick some Zetec s bumpers, spoiler and skirts cheap enough
sikora
Your car: XR2i, Clio Trophy
Postby jonyb4 on Sun Mar 28, 2010 5:49 am
take alook in the project threads section of the main board, look for inspiration from mk5 owners like Mada and Dontpannic
but to be honest this sint the best forum for mk5 as its mainly mk3 fiesta's based here
