in need of some help and info
2 posts • Page 1 of 1
ok people.
I live next door to a kit car manurfactures. And have just been to see them about having a little engine transplant.
We sat down and got talking, in the end it was decided that a 2.0litre 16v with throttle bodies or twin 45 carbs would be best for me. Also he would be doing a brake conversion so i can stop it lol.
The questions are will it all fit into a mk4 fez?
How much has he got to change e.g. wire loom, gearbox etc....?
Is the engine with the bodies or carbs, the brake conversion and labour worth £4000?
He's asked me to find out as much info as i can (as he hasnt fitted 1 into a fiesta before). So all info would be gratefully recieved.
thanks
thanks
- phatfiesta
Re: in need of some help and info
phatfiesta :ok people.
thanks
It's not as easy putting it in a mk4 as it is in a mk3. they use a the zetec-se engines in the mk4's, not the zetec-e engines you find in the mondeo. nothings impossible, but you'd need to do a lot of work to get it in.
on the other hand, the puma 1.7 will go in pretty much straight forward from what i've heard
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
