Induction Kit For XR2i 8V Help please
6 posts • Page 1 of 1
as title reads, had a look at mixons diagrams but im useless with engines...seriously....
i also have a lil problem when sitting in traffic and plodding along, car jumps just a lil when going really slow..have to put foot on clutch to stop it and stop car from stalling....
heres a couple of pics of my engine if someone could help with the induction kit and wheres the iscv? think i might soak it in petrol see if that helps....Thanks
Ade
Ade
- Faith
At the back of the bay, just to the right of your header tank. The shiny thingy with two pipes and one plug - thats the ISCV.
If you're going to clean it remove it from the car, undo the 2 screws the seperate the 2 halves. Then, just soak the valve side in petrol, or spray some carb cleaner. Soaking is much better if left for a few hours. Dont soak the solenoid part (the one with the plug on it).
Refitting is reverse of removal
- PaulC
Yep if you go for a K&N its system no 2. Not sure if Piper X make different kits for the various iscv setups
- JamieFRST
- Keep It Tidy
Would you say go for K&N then? or how about RAM Air or jetex??
im also considering buying a Pipercross cold air feed pipe, is there any problems with using one of these aswell as if the K&N comes with one?
ade
ade
- Faith
