Induction kit : Tuning / Handling / Braking | Fiesta Forums
Induction kit
Induction kit
Postby Carlos-w on Fri Jan 11, 2008 11:00 am
how do i get an induction kit on this?
BTW. this isnt my actual engine its just identicle to mine :D
Carlos-w
Re: Induction kit
Postby Smo on Fri Jan 11, 2008 12:25 pm
The only thing you can really do is change the air filter element inside, or change the whole air box for a bolt-on filter, but don't expect any performance gains at all!
If it's for noise, then a lot of people drill the airboxes around the side (not something I've ever done!) - I think there may be a guide on how to do this in the Guides and FAQs forum :)
Smo
Re: Induction kit
Postby Wardy257 on Sat Jan 12, 2008 11:56 am
Shouldn't this be in the Styling section? Induction kits are not tuning.
XR4i
Mk2 3.0S X Pack Capri
ZETEC Mk 1 Escort
Fiesta Si 1.6
Wardy257
Re: Induction kit
Postby Luke1990 on Sat Jan 12, 2008 6:20 pm
Wardy257 :Shouldn't this be in the Styling section? Induction kits are not tuning.
I know you are trying to be "rood" but any engine modification should be under tuning. In my books the air intake whatever the method, is fairly engine critical :wink: Besides an induction kit will give performance gains, albeit minimal but gains nonetheless along with a slightly improved responsiveness. Finally id of thought the moderators were perfectly capable of running the forums.
Luke1990
Re: Induction kit
Postby Wardy257 on Sun Jan 13, 2008 12:12 pm
Luke1300 :Besides an induction kit will give performance gains
That is a pretty bold statement, got any proof?
XR4i
ZETEC Mk 1 Escort
Fiesta Si 1.6
Wardy257
Re: Induction kit
Postby Luke1990 on Sun Jan 13, 2008 12:29 pm
Wardy257 :
how did you manage to misquote a three line post?
and in answer no i do not actually have a full rolling road system accurate to within half a bhp sitting here on my door step but it would be a much bolder claim that there are absolutely no additional benefits to be had from installing one.
Besides its fairly fundamental that a less restrictive intake will free up more power i.e. maximize gains from other modifications. Besides are you not arguing in the other thread how much of a performance gain you get from a big exhaust? :lol:
Luke1990
Re: Induction kit
Postby Oranoco on Sun Jan 13, 2008 12:33 pm
On some cars the fitment of an induction kit can make some pretty healthy gains. I've seen 7-8bhp on some engines. Also seen and expereinced power losses by their fitment hence why my A4 now has reverted back to the standard filter
Oranoco
Re: Induction kit
Postby Wardy257 on Sun Jan 13, 2008 1:01 pm
Luke1300 :Besides its fairly fundamental that a less restrictive intake will free up more power i.e. maximize gains from other modifications. Besides are you not arguing in the other thread how much of a performance gain you get from a big exhaust? :lol:
It is fairly fundamental that you have to know an intake is restrictive before you can make it less restrictive. Have you got a flow bench out?
I am not arguing that big exhaust gives more performance on another thread, I am arguing that it that given situation the exhaust has increased flow through the engine. This does automatically mean more power!!!
XR4i
ZETEC Mk 1 Escort
Fiesta Si 1.6
Wardy257
Re: Induction kit
Postby j7aoc on Sun Jan 13, 2008 3:04 pm
If you tell me you make and model engine size/type eg cfi i will tell you what you can have and how much. And this is in the right forum end of!!!
j7aoc
Re: Induction kit
Postby Carlos-w on Sun Jan 13, 2008 8:29 pm
its a mk3 M reg 1.3 injection
Carlos-w
Re: Induction kit
Postby j7aoc on Sun Jan 13, 2008 10:22 pm
I thunk yours is a fiesta 1.3i cfi ohv 1991/1996 k&n only list the element E-9090 £44.66 Only other ways is mod a bolt on filter im sure some off here did this
j7aoc
Re: Induction kit
Postby Luke1990 on Sun Jan 13, 2008 10:55 pm
if you check through Haynes you can find the name of the Carb. from this you can find the correct Bolt on filter, was looking into one for my old 1300 hcs but its like £59 so didnt bother..
Luke1990
Re: Induction kit
Postby edders on Sun Jan 13, 2008 11:10 pm
i was told that you can fit the K&N off the orion as its the same injection system. same is true of most of the older smaller engined fords.
8 slices, 4 Sandwiches.
edders
Re: Induction kit
Postby Carlos-w on Mon Jan 14, 2008 2:45 pm
so the 9090 is just a replacement filter so that will do f**k all to my performance then aye?
Carlos-w
Re: Induction kit
Postby j7aoc on Mon Jan 14, 2008 3:45 pm
Carlos-w :so the 9090 is just a replacement filter so that will do fouquette all to my performance then aye?
It is expencive for what it is but it would be better the the standard one as it will let the engine breather better you get what you pay for
j7aoc
Re: Induction kit
Postby Tweek on Tue Jan 15, 2008 2:11 am
It's been known that you can fit the 1.4/1.6 K&N Bolt on to the HCS engines. Can't remember it what it involved but it's been done. Part number for that was the 56-9042 I think :)
Your car: VW Golf GTD
Re: Induction kit
Postby Luke1990 on Tue Jan 15, 2008 10:17 am
56-9042 is the one specified for the carb on the HCS its also for a lot of older fords. At least thats what my research turned up :D
Luke1990
Re: Induction kit
Postby Ratspeed on Tue Jan 15, 2008 7:29 pm
Tweek :It's been known that you can fit the 1.4/1.6 K&N Bolt on to the HCS engines. Can't remember it what it involved but it's been done. Part number for that was the 56-9042 I think :)
I think its pretty much just drill the mounting holes in the bottom plate of the bolt on filter to line up with the carb/injection
Ratspeed
Re: Induction kit
Postby Andyfloss03 on Thu Jan 17, 2008 3:24 pm
Green stuff do a bolt on filter for this engine
trouble is its expensive i think
so i just went for the drilled holes
as i wanted the noise :D
Andyfloss03
