Induction kit
3 posts • Page 1 of 1
Induction kit
Can someone tell me about induction kits on an si as well?
CUz im used to carbs.
Do i need a cold air feed?
Will i get all i need in the kit?
What does the kit consist of?
What size is the filter?
What do i do with the filter, do i conect it then put it back in that black box, or jus dump the black box etc?
Someone please help.
- PUREtom
will be fine without but a cold feed would be better
if you get say a K and N you will but some cheap ones miss clips and brackets but easy to DIY fit
Cone filter, hose, bracket, filter oil?
85mm if i remeber correctly
no box needed
no box needed
- ch1ef
