inlet manifold!! frst
Postby riles@ on Tue Jul 06, 2004 2:41 pm
can a 90 spec xr3i inlet manifold be used on a frst???
any info on inlet manifolds for a fezzer turbo would help!!!
cheers :Q
riles@
Postby Project on Tue Jul 06, 2004 2:51 pm
Yep, but you need to use the FRST IAT sensor (top gearbox-side of inlet manifold), and replace all the gaskets with new ones, torqueing them up to FRST settings.
/Munk
Project
fiftyoneCL
fiftyoneCL
Postby riles@ on Tue Jul 06, 2004 2:56 pm
so it goes straight on only changing the gaskets to frst.
i the map senor for frst!!! is there a plug hole for the senor then!!!
riles@
Postby Project on Tue Jul 06, 2004 3:10 pm
Use the FRST MAP sensor you have on the bulkhead.
The IAT sensor needs to be fitted with the adaptor, which is a standard thread size and available from plumber's merchants if needed.
/Munk
Project
fiftyoneCL
fiftyoneCL
Postby riles@ on Tue Jul 06, 2004 3:23 pm
whats the IAT senor for !!
riles@
Postby Project on Tue Jul 06, 2004 5:17 pm
Inlet Air Temp :)
It's 0FAB/0FAC-specific afaik, hence rare :(
/Munk
Project
fiftyoneCL
fiftyoneCL
